New Scorpion Headlight - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 04-26-2013, 08:54 AM Thread Starter
Have them running without DRL.
6michaud is offline
post #2 of 9 (permalink) Old 04-26-2013, 11:48 AM
RedThunder's Avatar
We need more pics then that!
RedThunder is offline
post #3 of 9 (permalink) Old 04-26-2013, 06:13 PM
TRUKNUT's Avatar
Looks Great ...
TRUKNUT is offline
post #4 of 9 (permalink) Old 04-26-2013, 08:51 PM
Need better pics as the 1 you posted ya can't see if there projector or a dual setup nothing, so better pics is a must.
post #5 of 9 (permalink) Old 04-26-2013, 09:28 PM
They look like a halogen projector plus halogen highbeam plus a tinted lens.
They look like my led tail lights looked.
Tinted lens chrome underneath.
How's the output? I can't imagine the tinted lens helps..
post #6 of 9 (permalink) Old 04-27-2013, 12:35 AM
1white08fx2's Avatar
Clicking the pic larger, it doesn't look to bad. Looks good.
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #7 of 9 (permalink) Old 04-27-2013, 03:41 AM Thread Starter
I will get more pictures
The out put is I see better than Stock!
*HID 6000K
*Dual Halo Eagle Eye Rings
*led stripe
*Smoked lens and the inside or underneath is black chrome
What I did though is I cut the wire for the eagle eye. I like the look but when on specially at night it was too much for my taste. So I now only have the HID and led stripe that fires. I also hooked my Relay harness so that the trigger wire connect to the park light instead of headlight like it is supposed to be. So this way during the day when switch off I have no light at all. Complete blackout.
Did you ever seen the Recon headlight? Its the same!
6michaud is offline
post #8 of 9 (permalink) Old 04-27-2013, 07:23 AM
Then yes.
I think they are all made by the brand "Spyder"
So your low beams are not hooked up to the low beam? They are hooked up to the parking lights?
If so, that's "not the way it should be".
Just get ford to shut the DRL off. Or just use a headlight bypass shutoff switch to override the DRL.. Then when you want them on use the switch to enable the headlights.
I had a set of those in a different color combo, which I pulled apart to upgrade because the output was so bad. I eventually just sold them to go better performance.
The halogen projector inside can be upgraded to an hid bi-xenon projector that has highbeam mode and way better width. With that upgrade your lighting output will increase tremendously as well as your visibility at night.
Your Headlights may look good during the day, but what good are they if they can't perform at night when you need them?!?!
post #9 of 9 (permalink) Old 04-27-2013, 08:34 AM Thread Starter
Then yes.
Thank you sir
6michaud is offline
pirelli scorpion atr 20" tires gewiens Wheels and Tires 21 09-15-2012 01:33 PM
Pirelli Scorpion ATR cracking shift6 F-150 2009 to 2014 Forum 7 12-19-2011 07:09 PM
NEED HELP: Headlight bulbs mataspr Super Duty Forum 14 04-12-2011 09:51 PM
burning headlight Roots Gas Engines 12 01-08-2011 03:03 PM
Burnt out headlight TRUKNUT Lighting 24 05-31-2008 10:38 AM
