NEED HELP: abs problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 08-20-2013, 07:58 PM Thread Starter
garrmo's Avatar
abs problems
running 315 on truck with 2 inch leveling kit in front had to do some minor cutting of shroud seems my abs kicks in and slows me down not for any particular reason im thingking its the tire size computer not adjusting correctly i do have a cortex chip whitch allowed me to change the tire size but does not seem to help any suggestions would be appriciated.
garrmo is offline
post #2 of 3 (permalink) Old 08-20-2013, 09:16 PM
TRNRBILT's Avatar
I've had the same issue once and awhile with my 2009 as well after the 2" lift and a cortex tuner aswell. I don't recall it happening though since installing the Tune and correcting for tire size (I'm only running 33's though not 35's). It seemed to happen more when turning and going over a bump (from road to sidestreet with slight bump) that it would kick it on. I'll have to check and see if it does it next time I'm out in the same spot it was always doing it before the tune.
TRNRBILT is offline
post #3 of 3 (permalink) Old 08-21-2013, 07:01 PM Thread Starter
garrmo's Avatar
same here as well turning with some speed not so good guess its back to 31" drag really like the look of the 35 thanks for the reply
garrmo is offline
abs light albertaboy Sticky Tech/How to Section 3 04-09-2016 01:22 PM
NEED HELP: ABS light Ol Skool Suspension 10 11-18-2012 05:49 PM
ABS light swampthing Diesel Trucks 2 09-29-2010 08:52 PM
ABS light swampthing Diesel Trucks 1 09-27-2010 07:42 PM
ABS heavyhitter F-150 2004 to 2008 Forum 6 12-16-2008 10:00 PM
