Wiring Third Brake Light on Canopy - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 12-31-2013, 12:51 AM Thread Starter
97350's Avatar
I'm looking for any info on where to tap in to the wiring harness on my 2010 for a canopy 3rd brake light.I'm also going to wire up the dome light but was going to tie into the park lights for this.Any help would be appreciated.
2010 150 Lariat Max Tow,Banks Monster Exhaust,Ultra Drifter Wheels
97350 is offline
post #2 of 13 (permalink) Old 12-31-2013, 09:52 AM
5pointslow's Avatar
i have the parts at home to do this myself. I looked into it about 8 months ago. and have yet to get to it. ha.
anyways, there is a wire under then hood that you attach to for the brake light.
and I think it was general consensus to run the one for the accessory light to the battery?
so you could use it at all times.
anyways. google is your friend, there is lotsa info out there.
5pointslow is offline
post #3 of 13 (permalink) Old 12-31-2013, 04:20 PM
What about the trailer wiring harness? You would still need to get power back for the dome light though
post #4 of 13 (permalink) Old 01-01-2014, 07:17 AM
Again, resident Mad Scientist Travis would be the reply I'd be waiting on.
I seem to recall he did a sweet LED setup under the bed rails , so a canopy light and third brake light for a topper would be cake.
post #5 of 13 (permalink) Old 01-01-2014, 12:59 PM
Canopy light, just wire to trailer wiring. I'd pick up a 4 pin trail plug and wiring and install the connector so if you want to take it off you don't need to cut it.
As for the dome light.
I ran a fused power wire from the battery hooked it thru a pin switch, can use a magnetic switch. When it's closed it breaks the circuit. When the door is open the switch sends / allows power to a set of lights.
post #6 of 13 (permalink) Old 01-01-2014, 01:02 PM
Told yah. lol
post #7 of 13 (permalink) Old 01-02-2014, 10:40 AM
5pointslow's Avatar
i think that the downfall of wiring it to the trailer wiring is that it will blink when you use the turn signal for whatever side it is wired to?
as the turn and brake lights are the same wire?
going on memory here and electrical is not my strong point.
there is a wire under the hood for the purpose of the brake light on a canopy.
if ford puts it in there, you know it must be for a reason.
FFS there isn't even a light under the hood or in the glove box anymore.......
the canopy also comes prewired with interior lights that you just need to hook up.
furthermore they also have a connector already attached to the lights similar to a four prong trailer wiring connector.
you just buy the other half from the cap dealer or it comes with the canopy when you buy it.
post #8 of 13 (permalink) Old 01-02-2014, 02:39 PM
7 pin harness has separate wired brake and signal.
Good it has the harness.
But why would I want it on with parking lights? How about when I open the rear hatch? And only when I open the hatch?
post #9 of 13 (permalink) Old 01-02-2014, 02:44 PM
5pointslow's Avatar
I think you're making this more complicated than required.
There are two separate lights, one for the brake on the exterior and one for the interior light on the inside.
I don't believe I understand your comment about having the light on when the parking lights are on?
as I stated, it is usually done where the interior light is wired directly to the battery.
the light has a switch on it, I guess you could add a second one to automate it to come one when you open the tail gate or something.
I am simple simon when it comes to wiring, I will be using what's there and doing it the easy way.
some one with more experience can make it fancier.
post #10 of 13 (permalink) Old 01-03-2014, 01:59 AM Thread Starter
97350's Avatar
After a couple of Google searches I found the best way to do this.
Ford leaves a green wire capped off in the engine bay above the drivers side wheel well for a third brake light. I tied into this one and ran another dedicated and fused wire from the battery to the canopy.It took a bit to run the two wires neatly but it was worth it and it works great.
If you were to tie into your trailer wiring you would end up with a flashing brake light on your canopy when the ts were put on.
97350 is offline
VHT Niteshades Third Brake Light Mod SVT4MT Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 50 02-03-2013 07:23 PM
3rd brake light leak fix seadragon F-150 2009 to 2014 Forum 6 02-14-2012 04:34 PM
Third Brake Light Water Leak Armen Exterior 5 12-16-2010 09:43 PM
looking for a canopy..... redranger Alberta 0 04-14-2010 09:37 PM
Recon 3rd brake light Black Ice Lighting 18 04-02-2009 03:22 PM
