Tpms fault - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 04-18-2014, 09:34 PM Thread Starter
TRNRBILT's Avatar
Tpms fault
Ok I just put the summers back on my '09 last night. I went around the block just to make sure everything was good (and show off the recently washed summer mode) and never had any issues. Today I drove 20-25kms to my uncles place and the TPMS light came on as well as a TPMS sensor fault on the display. It didn't list a tire that is low. All are at 30psi. I ran these rims and tires all last summer and never had an issue. They have OEM ford sensors installed in the tires. Any ideas?
Thanks James
TRNRBILT is offline
post #2 of 11 (permalink) Old 04-19-2014, 04:33 AM
When I get winters/summers swapped, the tech always has to go around to all four corners and scan in the new TPMS sensors so the system will recognize they're back on the vehicle.
I've had years where they have forgotten, got about five kilometres away and had the light come on, turned out they forgot to scan them in.
Got the TPMS sensors on both of my sets, so the only thing I can guess is that if the pressures are good, you need to get the sensors "introduced" to the computer maybe.
It's like a voodoo ritual, you gotta turn the key on and off three times fast, hit the brake twice and then go around to all four corners, horn beeps each time to acknowledge it worked.
Just a thought.
post #3 of 11 (permalink) Old 04-19-2014, 06:06 AM
TRUKNUT's Avatar
This happened to me the first time I had my tires changed at the dealer . When I called to ask what I should do they told me to drive the truck several km and the computer would pick up the TPMS sensors . By the time I got home the display lights were out .
TRUKNUT is offline
post #4 of 11 (permalink) Old 04-19-2014, 10:26 AM Thread Starter
TRNRBILT's Avatar
Well I've tried all the reset methods that I could find on the internet for doing it without the tool and none work. I can get it to go into the learn mode but then it won't pick up the tire. It's strange because last year I just swapped from my stock tires to the summers and everything worked fine. Switched back to my stockers in the fall and all was good. Now it won't go out for the summers. I've got a buddy who has a reset tool so I'll have to give it a try.
TRNRBILT is offline
post #5 of 11 (permalink) Old 04-19-2014, 01:03 PM
Canadian Bacon's Avatar
Reset tool is $40 go buy it at the dealer. If you keep driving it should re learn on its own. If not I vote for a bad sensor. Maybe the battery died.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #6 of 11 (permalink) Old 04-20-2014, 02:58 PM
First verify the correct tire pressures. Isn't the spec 35 psi on these? Reference the placard on the driver's door.
Following that attempt to train all of the sensors. The tool can be had over the parts counter at your local Ford store - I'll provide the tool # off of mine when I go to work tomorrow. My cost was $25, yours will likely be in the $40 range as mentioned.
The training procedure is key on 3 times quickly, press the brake pedal once, key on 3 times quickly and finish by leaving the key on. This has sequence must be completed in approx 8 seconds.
Start by training the l/front, then r/front, r/rear and finally l/rear. The horn will honk each time a sensor trains, and after successful training of all four tires the cluster message centre will read 'training complete'.
If one tire will not train move to the next tire. Then go back to the suspect sensor and retry. If it still will not train then you have your answer.
Varsity Tyler is offline
post #7 of 11 (permalink) Old 04-21-2014, 11:49 AM
Tool Part # TPMS-19
Amsoil Home Page
post #8 of 11 (permalink) Old 04-21-2014, 08:15 PM
Sorry to hear you're having TPMS problems. As some of you know, I'm a big fan of this technology. It solves the hassle and outrageous expense of checking tire pressure the old fashioned way, once and for all.
https://www.youtube.com/watch?v=tKdcjJoXeEY
Or not.
post #9 of 11 (permalink) Old 04-21-2014, 08:27 PM Thread Starter
TRNRBILT's Avatar
Or not.
Hahaha. Ya that's exactly how I feel about them. I check tire pressures still even with them. I'm not concerned about them not working it's just the light being on all the time that I can't stand.
TRNRBILT is offline
post #10 of 11 (permalink) Old 04-22-2014, 07:12 PM Thread Starter
TRNRBILT's Avatar
Got it all fixed today. Was taking a second look at the princess auto flyer at work seeing what I could waste my money on this week and wouldn't ya know it they had an AUTEL TS401 tool on sale for $200 instead of $320. A little more than the ford tool but this one does every vehicle on the road (even Honda motorcycles). Also tells you the tire pressure in each wheel when programming it, the id #'s of each sensor, tire temps, battery condition and also can check key fob batteries and frequencies. Figured if I'm going to need the tool I might aswell get the tool that can do it all.
TRNRBILT is offline
It's Ontario's fault! where do I put it?? Ol Skool Interior 42 03-01-2012 10:05 AM
TPMS teknoteach Wheels and Tires 25 10-05-2011 01:21 PM
tpms reset tool benyl F-150 2009 to 2014 Forum 5 12-20-2010 05:38 PM
TPMS? ric_no_k Wheels and Tires 16 09-19-2010 11:59 PM
TPMS for 2004 SCrew? SCrew Lariat F-150 2004 to 2008 Forum 0 07-12-2010 01:29 AM
