Head light change - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 02-25-2015, 03:57 PM Thread Starter
2MUCH's Avatar
Head light change
So how do you change the bulbs in the headlight. I bought some new white lights to change out the stock light. I look under the hood and I don't see how to get to the bulbs to replace them.
2MUCH is offline
post #2 of 9 (permalink) Old 02-25-2015, 05:36 PM
Don't quote me on this, but I believe that when I swapped my '09 FX4 headlights (stock halogens) for blacked out Raptor headlights, (again halogens), I think they were a sealed unit
Plug and play, it seems to me that to replace the bulb you had to replace the entire headlight assembly, but something about that sounds awful familiar.
Maybe someone with a better memory or more hands on could tell you.
Where's that damn resident Mad Scientist when you need him, he'd be the guy that would know.
post #3 of 9 (permalink) Old 02-25-2015, 06:45 PM
If a 09+ is like my 05 you have to remove the headlight and then access the bulbs from the back.
post #4 of 9 (permalink) Old 02-25-2015, 06:46 PM
Found this with a quick google search. Seems thorough. Similar process to 04-08 trucks.
http://www.paulstravelpictures.com/F...acement-Guide/
post #5 of 9 (permalink) Old 02-25-2015, 07:52 PM Thread Starter
2MUCH's Avatar
Thanks for that website link. It sure looks like a lot of work to just change a bulb
2MUCH is offline
post #6 of 9 (permalink) Old 02-25-2015, 09:57 PM
TRNRBILT's Avatar
It is. They definitely didn't think it through very well.
TRNRBILT is offline
post #7 of 9 (permalink) Old 02-26-2015, 05:24 AM
They thought it through perfectly! If we make it a pita enough, they'll pay us to change it. The customer loses, the mechanic loses, the "stealership" wins.
post #8 of 9 (permalink) Old 02-27-2015, 09:16 PM
its pretty easy actually.
little plastic screw to remove the weather mat. then 3x10mm bolts. pull straight out.
turn the bulb out, unclip the connector. replace bulb, twist back into place.
align the asseblly. give a good push inward. will click/klunk back into place.
replace 3 bolts.
litterly couple mins to do.
post #9 of 9 (permalink) Old 02-28-2015, 07:56 AM
Told yah, thanks for checking in Travis, looks like I was wrong with the sealed unit idea.
Meh, isn't the first time, won't be the last, main thing is I keep trying. lol
Projector head light adjustment Mrmagoo Exterior 2 01-05-2012 11:19 PM
6.0L head studs Axehandler Super Duty Forum 4 02-28-2010 07:32 AM
4.6 Cylinder head Fordwheeler Gas Engines 0 11-06-2009 08:24 PM
Head Gasket on an 07?? 07rangersport Ranger Forum 15 02-02-2009 12:12 AM
