Remote entry batteries - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 05-01-2015, 01:59 AM Thread Starter
Anyone remove the standard CR2032 battery and replace with two CR2016 batteries? Did it make the range better?
TeamGreen is offline
post #2 of 5 (permalink) Old 05-01-2015, 09:40 AM
Canadian Bacon's Avatar
How would it make the range better?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #3 of 5 (permalink) Old 05-02-2015, 11:40 PM Thread Starter
I was just doing some reading about remotes and the batteries in them, it was suggested under another manufacturers site
post #4 of 5 (permalink) Old 05-03-2015, 11:04 AM
Stacking two CR2016 connects them in series and would double the voltage. That might fry the remote.
1970 F250 -> 1977 F350 -> 1978 F150 -> 2003 Ranger -> 2010 Ranger -> 2014 F150 -> TBD
willyg is offline
post #5 of 5 (permalink) Old 05-04-2015, 06:44 AM
A fresh battery will boost range but don't go using batteries of different voltages. While cr2032 and cr2016 are the same voltage they do have different current ratings. Don't use them in series. A good cr2032 (ie Duracell) are not expensive.
Keyless entry handle wiring cdnarmyguy F-150 1997 to 2003 /04 Heritage Forum 0 10-03-2011 08:46 PM
Batteries LayinHp Diesel Engines 7 08-22-2010 12:13 AM
Keyless entry keypad b4000 Ranger Forum 0 08-08-2009 02:11 PM
CONTEST: ROTM Contest Entry Rules. jdcrush R O T M - Voting & Monthly Winners 0 05-01-2009 11:39 PM
How to use Keyless Entry Pad & Programming remote transmitters Oreo Sticky Tech/How to Section 5 08-17-2008 11:03 AM
