2009 F150 integrated wheel actuators - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 11-21-2015, 02:44 PM Thread Starter
Anyone have issues or replace the actuators, on their f150. Only 48,000 km on the truck.
BMyatt is offline
post #2 of 11 (permalink) Old 11-21-2015, 02:48 PM
Welcome, hope you find some answers.
post #3 of 11 (permalink) Old 11-21-2015, 02:55 PM Thread Starter
Thank. Seems like a great information site.
BMyatt is offline
post #4 of 11 (permalink) Old 11-21-2015, 07:00 PM
Very common on the 04-08 trucks but not unheard of on newer trucks either.
Mine went in my 05, ran without 4wd for a couple years before finally getting it done at Ford. It wasn't cheap but it's fixed.
Just an FYI, don't just assume it's just the IWE, test the entire vacuum system that operates the 4wd engagement. If there is an issue causing partial engagement you could trash the new IWE too.
post #5 of 11 (permalink) Old 11-21-2015, 08:31 PM
Welcome to the site. Have you checked to see if one side or both not working?
post #6 of 11 (permalink) Old 11-21-2015, 09:06 PM
If you want to do some reading check this out.
http://www.f150forum.com/f72/how-dia...m-esof-186872/
post #7 of 11 (permalink) Old 11-22-2015, 10:58 AM Thread Starter
Vacum seems to be functioning, constant grinding in the front wheels. I was just thinking if there is a way to replace what seems like a very fragile system with a warn manual hub system. If the original system didnt last very long. Love the truck but with only 48,000 km i shouldnt have to fix the 4x4 system. Warantee is timed out.
BMyatt is offline
post #8 of 11 (permalink) Old 11-22-2015, 11:04 AM Thread Starter
Thanks very interesting.
BMyatt is offline
post #9 of 11 (permalink) Old 11-22-2015, 05:32 PM
Know the feeling, I lost mine at relatively low mileage.
Unfortunately there are no manual hub options out there that I've come across in my extensive research on IWE's.
post #10 of 11 (permalink) Old 01-24-2016, 08:42 PM
Pyro3601's Avatar
There is the RCV IWE delete kit. It's a sleeve that eliminates the IWE and just locks and turns the front end at all times. You might maybe see a one point drop in mpg. But to me it's worth it not to end up stuck without my 4x4.
12 SVT Raptor Screw
Pyro3601 is offline
ABS & Integrated Brake Controller bunkered Diesel Trucks 3 03-27-2012 03:38 PM
anyone wheel there F150? Frumpy F-150 1997 to 2003 /04 Heritage Forum 9 06-22-2009 06:37 AM
1999 F150 won't engage in 4 wheel drive ChrisB Driveline and Transmission 3 03-27-2009 03:06 PM
03 F150 XTR xtend cab-wheel bearings gman F-150 1997 to 2003 /04 Heritage Forum 5 06-29-2008 07:46 PM
F-150 Integrated Wheel end Disconnect (HUB) fordtough.ca Wheels and Tires 0 02-11-2008 09:20 PM
