valve job or replace head? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 12-21-2015, 03:51 PM Thread Starter
have a non electrical dead #8, was wondering if I should do a valve job or replace the head?
macka is offline
post #2 of 4 (permalink) Old 12-21-2015, 05:26 PM
Yes!
post #3 of 4 (permalink) Old 01-20-2016, 11:32 PM
I am assuming this is a 5.0?
If so, replace both cyl heads. They are reasonably priced from Ford these days due to volume of sales. The valve guides have been redesigned to stop the issue of the valves pulling into the seats. All cylinders do it, but for whatever reason cylinders 4 and 8 tend to be the first ones to show up.
I have done many of these, and all of the ones done as retail I recommend doing both heads. If one is shot the other is very close behind.
Varsity Tyler is offline
post #4 of 4 (permalink) Old 01-24-2016, 08:32 PM
Pyro3601's Avatar
What he said! Tis a bit of a piece of mind thing just doing em both at the same time. Rather then doing one. Only to have the other side fail couple months later and have to tear it all open again.
12 SVT Raptor Screw
Pyro3601 is offline
NEED HELP: 6.4 L oil pressure relief valve failure dbullis Diesel Trucks 3 11-19-2014 10:21 AM
HUMMM?? 3 valve 5.4 into an '01 f150 2wd I like Fords Too F-150 1997 to 2003 /04 Heritage Forum 30 06-11-2013 02:37 PM
4.6L 2-valve to 4-valve? Raymond F-150 1997 to 2003 /04 Heritage Forum 1 01-04-2010 07:39 PM
pcv valve k dag F-150 2004 to 2008 Forum 3 06-17-2009 02:40 PM
I6 pcv valve question Ottawaguy F-150 Pre-1997 Forum 1 02-17-2009 08:39 PM
