Rear tires binding/skipping - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 06-04-2016, 01:26 PM Thread Starter
Jack-Daniel's Avatar
Parking lot speed when turning,some growling also.
I'm assuming clutch pack in the back ? Any other ideas ?
168,500 km.
Jack
Jack-Daniel is offline
post #2 of 8 (permalink) Old 06-05-2016, 07:37 AM
When was the differential oil level checked last? It sounds like you're in the right area.
post #3 of 8 (permalink) Old 06-05-2016, 08:27 AM Thread Starter
Thanks. It was checked in February and showed OK. The problem is noticeable after a highway drive (2-3hrs.) , then lessens after an over night cool down.
It was real bad when I got back from Elliot Lake,then OK in the morning.
It goes in to Exeter Ford on Monday.
post #4 of 8 (permalink) Old 06-05-2016, 12:17 PM
Definitely worth having a look, good luck for a fast and easy (i.e.- inexpensive lol) solution.
post #5 of 8 (permalink) Old 06-06-2016, 07:33 AM
Probably should, at the very least, drain and refill the diff. Gear oil with friction modifier does wear down. Probably uses 75w140 synthetic w/modifier. I haven't looked up the particulars, though.
post #6 of 8 (permalink) Old 06-06-2016, 07:52 AM Thread Starter
Ya,that's the first thing we're trying, then drive it for a couple of days.
2011 F150..5.0 XTR Super Crew
post #7 of 8 (permalink) Old 06-06-2016, 02:33 PM Thread Starter
Service manager was reluctant to change the clutch packs. They drained some fluid and added some friction modifier. He also suggested finding a parking lot with room to do figure 8s for awhile to get the fluid into the clutch plates. No charge .
post #8 of 8 (permalink) Old 06-15-2016, 03:56 PM
CDM76's Avatar
I had this problem with my 2010. Until I realized it was in 4x4. Somehow I accidentally twisted the switch into 4x4.
Happened a couple more times and when I checked it was always in 4x4. Turned the 4x4 off and no problems.
CDM76 is offline
NEED HELP: Tires: It's time for me to change the tires... WHICH ONES? will99 Super Duty Forum 6 04-11-2013 10:30 AM
Rear Ended Ghosthex13 F-150 2009 to 2014 Forum 30 08-25-2011 11:17 PM
My new rear bumper Seb_L Photo and Video Gallery - Members Rides 9 06-18-2010 04:04 PM
small lift in the rear.. rear shocks? Viper238 Wheels and Tires 9 02-04-2008 06:54 AM
