Front left caliper seized - 2010 F150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 4Likes
  • 2 Post By SVT4MT
  • 1 Post By shelly66
  • 1 Post By SVT4MT
post #1 of 5 (permalink) Old 07-07-2017, 12:46 PM Thread Starter
Yesterday I heard the ominous grinding of brakes. When I checked it turns out the front left pads are almost gone and the rotor is scored pretty badly. It turns out the caliper seized. I was wondering if I can get away with only replacing the scored rotor since the front right looks fine. I plan on replacing all 4 pads.
Deerlake is offline
post #2 of 5 (permalink) Old 07-07-2017, 05:22 PM
Depends on your level of comfort....yah, you could only repair the one side, but then you've got two different sized rotors, how long before the second one goes bad?
Yah you could do one side, but just because you could, doesn't mean you should. lol
Personally, IMO the better path is to bite the bullet and do both sides and get a fresh set of pads and rotors on each side.
Tires and brakes are two places I'm nervous about cutting corners to save a few bucks, seeing as they're responsible for getting me home safe.
Then again, it doesn't really matter what anyone thinks, its your ride and your cash when you get right down to it.
herbz and Destructicon like this.
post #3 of 5 (permalink) Old 01-01-2018, 06:49 PM
I had my brakes and rotors replaced last spring , I ordered the parts off of ebay from urban auto parts in Toronto cost me about 280 bucks for the whole kit and they are the good ones zinc slotted and the pads are good to, good quality , I found a semi retired mechanic on kijiji and he installed them for 100 bucks , can,t beat that kind of deal man.
Deerlake likes this.
shelly66 is offline
post #4 of 5 (permalink) Old 03-04-2018, 08:15 PM Thread Starter
I actually only replaced a caliper and the one rotor that had been scored. I put new pads on both sides though. It has been fine since last July,
Deerlake is offline
post #5 of 5 (permalink) Old 03-05-2018, 04:07 AM
Glad to hear its working out for you, good update.
Left Front Speaker Issues Rough Rider F-150 2009 to 2014 Forum 10 07-27-2012 01:24 PM
rubber mounted metal piece on rear caliper parkside F-150 2009 to 2014 Forum 0 06-16-2012 05:20 PM
2010 F150 or 2011 F150 benyl F-150 2009 to 2014 Forum 29 09-18-2010 10:06 AM
Brake Caliper Lube tohi2care Suspension 2 05-14-2009 12:14 PM
F150 Front Plate Bracket canadian redneck F-150 2004 to 2008 Forum 6 02-24-2008 12:27 AM
