replacing Tie rods - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 10-26-2017, 03:10 PM Thread Starter
replacing Tie rods
I also have a Ford Escape and when I was getting new tires put on it they said that the right outer needed to be replaced. Do you think I should replace both the left and the right at the same time?
I was thinking I should since I will have to get an alignment done.
Deerlake is offline
post #2 of 9 (permalink) Old 10-26-2017, 05:47 PM
I'm guessing that if the right is gone, the left can't be far behind. Alignment will get you set straight.
post #3 of 9 (permalink) Old 10-26-2017, 06:22 PM Thread Starter
That's what I was thinking. Why wait and then have to do the left side and then get an alignment done again. I can't do my own alignment so the savings will be in replacing the tie rods.
thanks for the reply.
Deerlake is offline
post #4 of 9 (permalink) Old 10-27-2017, 12:43 PM Thread Starter
Ford vs Moog tie rods
The Ford dealer wants $106 for each outer tie rod. Canadian Tire sells Nascar Tie rods which supposedly are actually made by Moog. They are on sale for $40. That is quite the difference. Does anyone have any experience with Moog tie rods? I don't want to use poor quality parts since they are so important. I am tempted to just buy the Ford parts so I don't have to wonder but I thought someone with more experience could give me some advise. Thanks.
Deerlake is offline
post #5 of 9 (permalink) Old 10-28-2017, 06:31 AM
I've always run Ford parts with no issues, depends on what you want to spend and what level of comfort you have with the parts you buy.
Ford parts have never given me a reason to look elsewhere, and I'll pay the extra cash for peace of mind and fit and finish quality. I'm not saying they're the be-all, end-all, but its whatever makes you happy and fits your budget.
No experience with the Moog stuff, but sometimes the saying "You get what you pay for" applies.
Then again, so does the saying "Your mileage may vary."
post #6 of 9 (permalink) Old 10-28-2017, 02:28 PM
I've have excellent experience with Moog parts. Better than Ford's, for the most part, and you can get them with grease nipples. If lubricated properly, they will be the last set you ever buy. The one to stay away from is AC/Delco.
post #7 of 9 (permalink) Old 10-28-2017, 06:44 PM
Heh heh heh.....greased nipples......heh heh heh heh......lubricate properly......heh heh heh
post #8 of 9 (permalink) Old 10-29-2017, 06:48 AM
And don't let these two change them.
post #9 of 9 (permalink) Old 11-03-2017, 08:58 AM Thread Starter
Smile
Those 2 guys are not coming anywhere near my truck lol.
FYI I found an alternative to Ford parts (for steering anyway) that I think will be really good. They are actually made in Canada.
About Us - MAS® Industries - Manufacturer of premium chassis parts.
There is a seller on Ebay called clickauto1 who is a retailer.
https://www.ebay.ca/itm/232537327124 - $38.95 and free shipping for each outer tie rod.
Deerlake is offline
882+tx for ball joints and tie rods + labor from the stealership pat_28 Suspension 11 11-20-2011 10:17 PM
