2009 F150: window seal corroding - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 03-07-2010, 03:30 PM Thread Starter
I've got an '09 extended cab. has 18,000kms . On the outside of the drivers side back window, there seal at the bottom of the window. The rubber seal at the bottom where 2 pieces butt together it is corroding underneath the seal at the joint and there is a white residue that is running down the door.
anyone else had this problem?
I'll see if I can snap a shot later.
post #2 of 2 (permalink) Old 03-07-2010, 08:06 PM
Blue Oval's Avatar
Sounds like the trim they've used on the Rangers for years.
It's rare that a truck that new would exhibit it, but from experience I can tell you that the rubber seal is actually a formed piece of steel coated with rubber on both sides.
If the rubber didn't make a perfect seal around the bottom half of the steel, you will have rust and corrosion very quickly. If you have a good relationship with your dealer, you should be able to get them to replace the trim piece without too much trouble. If they won't, I'd bite the bullet and buy a new one before it screwed up the paint. If memory serves they were about $50 apiece for the Ranger, should be a little less for the 150.
Blue Oval is offline
2009 F150 Sony Navigation bruins.4 F-150 2009 to 2014 Forum 24 11-08-2009 05:50 PM
2009 F150, who bought one? fordtough.ca F-150 2009 to 2014 Forum 43 06-15-2009 12:24 PM
2009 F150 Prototype here to see and touch Blackstock F-150 2009 to 2014 Forum 2 07-23-2008 01:08 AM
2009 F150 Booklet!! get yours now!! Phantom Wolf F-150 2009 to 2014 Forum 10 02-02-2008 02:40 AM
