Driveshaft Slip/Bump TSB 09-25-5 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 04-18-2010, 09:30 PM Thread Starter
Has anyone experienced this problem, where you feel like your truck is being bumped when either stopping or accelerating from a stop? Also wondering if anyone has had this problem fixed at the dealer through the TSB that came out? I am experiencing this problem and just wondering if I am going to run into any problems at the dealer trying to get it fixed. Thanks.
scottsherriffs is offline
post #2 of 5 (permalink) Old 04-18-2010, 10:49 PM
I would just call tell them the problems your experiencing.
Make an appt for them to look at the truck. But I wouldn't mention the TSB.
They will look in the computer and see the TSB.
post #3 of 5 (permalink) Old 05-24-2010, 10:22 AM
I had the same problem on my 09 screw. Brought in last week for an oil change and mentioned it to the service dept. They test drove it, confirmed the problem and did the required repairs as per the tsb. Everything is fine now. Insist on them repairing it as per the tsb. Don't take no for an answer. If you have to take the tech for a ride yourself.
aliva is offline
post #4 of 5 (permalink) Old 06-09-2010, 09:30 AM
I have a two week old 2010 F150 with the same problem. It is going into the dealer Thursday for that along with a really squeaky rear suspension and front bumper misalignment. Trruck build date was April 2010.
rootem is offline
post #5 of 5 (permalink) Old 06-09-2010, 01:08 PM
TRUKNUT's Avatar
I had the same problem on my 09. Went to the dealer I bought the truck (ERINWOOD FORD) To big of a problem for there so called techs. To much trouble to check for a TSB
on this. They said this was normal !!!! So I went to Airport Ford in Hamilton. Problem solved in about 30 min. They checked for a TSB and had a solution. Just a little grease and an adjustment to a hanger bearing.
TRUKNUT is offline
Slip yoke play maurice727 Ranger Forum 4 03-18-2010 01:11 PM
CAR/TRUCK SHOW PICTURES: Slip on Tow Mirrors rgoulet58 F-150 2009 to 2014 Forum 1 03-16-2010 11:42 PM
Front driveshaft absent Bigwill Super Duty Forum 4 09-09-2009 08:43 PM
leak at the back of rear driveshaft Grizzly F-150 2004 to 2008 Forum 9 05-16-2009 11:38 PM
Limited Slip Matty Ranger Forum 14 12-03-2008 02:48 AM
