What a Difference in Towing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 06-08-2010, 12:21 AM Thread Starter
rgoulet58's Avatar
Finally got to use my new truck to tow my 23' Toy Hauler. What a difference over my old 02 F150 4x4 4.6/355 gears. The old truck would rev around 4200 at 100Kph on flat road (OD off). The new 2010 4x4 5.4/373LS and max tow revs at around 2000 at 100Kph. TT with large 4 wheeler and all the gear for a long weekend is around 7000lbs. Was very impressed how well it handled and even tried cruise for a bit and it worked well.
rgoulet58 is offline
post #2 of 10 (permalink) Old 06-08-2010, 02:47 AM
glad you're happy with it
post #3 of 10 (permalink) Old 06-08-2010, 02:06 PM
Seb_L's Avatar
Must have seen quite a difference in gas spent too
2008 Ranger FX4
Seb_L is offline
post #4 of 10 (permalink) Old 06-08-2010, 02:46 PM
it seems they did there homework on these newer trucks and got the torque curve just right
post #5 of 10 (permalink) Old 06-09-2010, 10:12 PM
Rrnb's Avatar
Thumbs up
That's great to hear. I just traded my f350 v10 for a 150 max trailer tow pack with 3.73's as well. I've got a 23ft. trailer dry weight 4900lbs and I haven't towed it yet with the new truck.Now I can't wait!
Cheers!
Rrnb is offline
post #6 of 10 (permalink) Old 07-17-2010, 12:21 PM
pbeitschat's Avatar
Talking
your not the only one who noticed a big difference, me too and I have the 4.6 , it stays at consistant rpm and speed and fuel mileage is better, me happy
pbeitschat is offline
post #7 of 10 (permalink) Old 07-26-2010, 10:26 PM
97350's Avatar
Did the truck have enough low end power to hold 100kph or does it slow down and then drop in and out of od repeatedly?I'm assuming that you can leave it in OD and select the towing mode...right?I'm curious because I'm interested in buying a new 2010 F150 2wd SCrew with the max tow pkg.I pull an 8500lb trailer.
97350 is offline
post #8 of 10 (permalink) Old 07-26-2010, 10:57 PM
either way it should be in tow mode o/d off for towing good way to burn up a tranny leaving it on light loads wuldnt be an issue but it will get hot on heavy loads
post #9 of 10 (permalink) Old 08-03-2010, 09:14 PM Thread Starter
rgoulet58's Avatar
You really can't compare it to the old 4 speeds with OD. The new 6 speed only has Tow Haul mode which I beleive still gives you 6 gears but changes the shift points for towing. I only had the one oppertunity to tow once this year and that was mostly flat road.. I'll have a better idea how well it tows Labour day weekend. Lots of hills on the 101 to digby.
08 23' RPM Toy Hauler
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
2010 F150 SC XTR Max Tow
post #10 of 10 (permalink) Old 08-03-2010, 11:59 PM
ric_no_k's Avatar
You really can't compare it to the old 4 speeds with OD. The new 6 speed only has Tow Haul mode which I beleive still gives you 6 gears but changes the shift points for towing. .
Yup, and makes it sound nice when you aren't towing. There is no way to shut the o/d off. You can pull it down to '3' but it will still hit o/d when the conditions are right. The tranny temp gauge is a nice feature.
The hill out of Bridgetown on my way to Keji was the worst one for me but I started from Berwick and didn't get to try Avonport. I was only hauling a tent trailer and some gear in the bed but I started at the bottom at 110 and got to the top at 100 and only dropped down a gear to get there.
ric_no_k is offline
Towing help Rustycan Ranger Forum 7 08-01-2009 07:17 PM
Towing cnelson09 F-150 2004 to 2008 Forum 1 05-03-2009 10:49 PM
NEED HELP: What is the difference? vernobc Ranger Forum 7 10-27-2008 06:38 PM
Plug types make a difference?? f150phule Gas Engines 4 02-04-2008 06:56 AM
