Trucks shakes like crazy at 120 km/hr + - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 07-16-2010, 07:18 AM Thread Starter
like it says... it's pretty smooth for a truck up to that speed, than it shakes like a bastard.
any ideas on how to fix? I've got the crew with 6.5 box, 5/4 l with 373 axle. Has the upgraded LT tires on it, and 33,000 kms.
It has done it mostly from the start. I usually drive on 90 km highways, so my speed is consistantly at 110 km's per hour... when I go to pass, it shakes crazy bad.
I just had an alignment done after changing out my tie rod.
any ideas how to smooth it out?
eros is offline
post #2 of 9 (permalink) Old 07-16-2010, 12:26 PM
Have the wheels rebalanced. Maybe a wheel weight fell off a rim? If it only has 33K, it should be under warranty, no?
post #3 of 9 (permalink) Old 07-18-2010, 10:52 AM
Thumbs up vibs
i found my rims on my 09 king ranch pick up mud and snow easily so have to keep clean or it will vib. also
zeke1030 is offline
post #4 of 9 (permalink) Old 08-11-2010, 09:16 PM Thread Starter
well, new tie rod and tranny flash.. still shakes like crazy. I'm going to book an apt with one of the techs, and go a ride with them to show them what i'm talking about.
eros is offline
post #5 of 9 (permalink) Old 08-11-2010, 11:14 PM
So it's only vibrating when downshifting to pass?..or even when steady speed?..bent driveshaft or missing weights on it? Maybe a fuel problem? Don't know man, hope the tech figures it out for ya
post #6 of 9 (permalink) Old 08-11-2010, 11:17 PM
Just a thought,may be a bulge in the sidewall? If the tread is starting to separate I found it gives a bad vibe at top highway speeds.
Ogre is offline
post #7 of 9 (permalink) Old 08-11-2010, 11:26 PM
Sounds a lot like a tire issue whether its balancing or maybe even that they are out of round or bulged.
post #8 of 9 (permalink) Old 08-13-2010, 02:58 PM
if you drive it smoothly to 120kmh does it vibrate or is it just when passing?
post #9 of 9 (permalink) Old 08-13-2010, 10:40 PM
More than likely it's either wheels, tires, or rotors. Could be the drive-shaft, but I would have thought that would be noticeable at much lower speeds.
Does the steering wheel shake? Try rotating the tires, it might give you a hint if it changes the vibration.
xciton is offline
new to trucks JosiahP New Members Introductions 11 06-21-2010 02:45 PM
My New Trucks zip F-150 Pre-1997 Forum 11 10-16-2009 02:47 AM
Trucks on Spike Smokefan SVT Lightning 12 05-04-2008 09:48 AM
Car Crazy Show Sunday Aug 5th taisa899 Ontario 2 05-27-2007 10:00 AM
