4WD sound - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 08-24-2010, 12:00 PM Thread Starter
4WD sound
Hey guys,
Just wondering if your trucks sound much different when in 4WD. Mine makes a whirring type sound when accelerating. My previous truck ('07 Tundra) did not make this kind of sound. Dealer checked it out and thought it was rather noisy so they contacted Ford Canada. They said it could be driveline wind up and said to just see if it gets worse.
Here's a video of the sound I'm hearing. It may be completely normal but as I said, my other truck didn't do this.
BTW, I don't normally drive in 4WD on pavement, this was just for demo purposes as I wanted a surface that wasn't too bumpy for the video. Tire pressures were all 39 psi and I drove in a straight line.
seadragon is offline
post #2 of 17 (permalink) Old 08-24-2010, 01:25 PM
ric_no_k's Avatar
Does the manual say something about not to using the 4wd on dry pavement? I have a 2wd so I can't tell you if I have the same noise
ric_no_k is offline
post #3 of 17 (permalink) Old 08-24-2010, 04:37 PM
You're on dry pavement, so wind-up. If I were your transfer case, I'd be moaning, too.
Does it make that noise on ground that has some "give" to it?
post #4 of 17 (permalink) Old 08-24-2010, 04:56 PM Thread Starter
No, as I mentioned, I don't usually drive on pavement in 4WD. It was only for this video as I wanted a smooth surface. The sound is exactly the same when driving on a gravel road. Haven't had a chance to drive it in the snow... yet.
post #5 of 17 (permalink) Old 08-24-2010, 06:30 PM
Ah. Seems odd then. I've driven various 4WD trucks, including an F150, GMCs, and my own Mazda, and I've never noticed any of them make a particular noise in 4WD. But I don't own a 150, so I couldn't say for certain. Lots of people here will know better, though.
post #6 of 17 (permalink) Old 08-25-2010, 12:04 AM
Mine kinda makes that noise. It's only 6 weeks old.
xciton is offline
post #7 of 17 (permalink) Old 08-25-2010, 02:00 AM
Most of my t-cases make noise, seems normal to me. 4 Low is even worse, especially around 40 - 50 km/h!!
Just be thankful you do have an old straight cut gear drive t-case, they whine worse than yer ol' lady on the rag LR
post #8 of 17 (permalink) Old 08-25-2010, 08:44 AM Thread Starter
Thanks for the replies so far. Sounds like its normal. However, if it were transfer case gear whine, wouldn't it be a constant sound? This sound seems to follow the gas pedal rather than the forward motion of the truck. It seems like it changes pitch as the torque converter locks/unlocks. But then it should happen in 2WD also.
post #9 of 17 (permalink) Old 08-25-2010, 09:12 AM
ric_no_k's Avatar
I don't think it would be a constant sound. When you are on the gas the sound would be worse as you are 'pushing' the gears to mate and to when you let off you remove some of the pressure.
ric_no_k is offline
post #10 of 17 (permalink) Old 08-25-2010, 03:20 PM
The t-case will get louder as you put more load on it, ie it will be loudest under acceleration and deceleration, whereas it will be relatively quiet when coasting under no load situations at constant speed on level ground. Thats just the sound of the chain you're hearing.
Unless its clunking, banging, or its binding up horribly in a straight line, I personally wouldn't worry about it at all. Even disengaging, the servo motor will clunk a bit if there's load on the t-case still, its normal. You'd be really amazed at what a t-case can handle. LR
No 4wd Low dave151 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 7 03-02-2011 07:50 PM
99 body swap from 2wd to 4wd QWKRN-U Ranger Forum 0 12-15-2007 10:30 PM
Problem with 4wd system???? Smokefan Wheels and Tires 17 11-30-2007 08:10 PM
welcome Selective Sound... SKRWZ New Members Introductions 3 11-15-2007 02:36 AM
