2011 Max Tow - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 09-24-2010, 07:24 AM Thread Starter
rgoulet58's Avatar
2011 Max Tow 3.5 EcoBoost only
The new 2011 F150 are up on the Ford sites. If you select Max Tow, it automatically selects 3.5 EcoBoost engine. Why can't you have the 5.0 with Max Tow. Will the $600 Optional Tow package give you the extra Leaf spring and 20:1 steering ratio like the Max Tow. I don't think so because GVWR has gone down to 7200 vice 7700. Also the Tow package does not give you the EBC, it's an extra option. Seems weird the lighter 5.0 with more HP and Torque than the 5.4 is rated less in towing capability which begs the question were the 09/10 5.4 overated at 11,300lb towing capability, not that I would tow more than 8000lbs with a F150 anyway but that's just me.
08 23' RPM Toy Hauler
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
2010 F150 SC XTR Max Tow
rgoulet58 is offline
post #2 of 6 (permalink) Old 12-10-2010, 05:19 PM Thread Starter
rgoulet58's Avatar
I see the 3.5 EB now showing up at dealerships across the country.
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
post #3 of 6 (permalink) Old 02-06-2011, 01:15 PM Thread Starter
rgoulet58's Avatar
I looked at several different dealerships across the country and could not find one 5.0 with a Max Tow package. A Super Cab or Super Crew 4x4 with 3.73 or 355 Ls and 5.0 has a GVWR of 7200 while the Limited with 3.73 Ls and 6.2 has a GVWR of 7350. All the Max Tow had the 3.5 EB w/373 LS and a GVWR of 7700 the same as my 2010 F150 3.73 Ls and 5.4
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
post #4 of 6 (permalink) Old 02-06-2011, 02:45 PM
If your building a 4x2 truck.
This is what i have found
Ford doesn't want you getting a 5.0 with a Max tow pkg. Also it seems as though you can not get LSD 3.73 gears with the 5.0.
Now if building a 4x4
Same deal goes for the Max tow pkg. have to have a 3.5L Eco.
but for the 5.0L you can get it with LSD 3.73 gears
post #5 of 6 (permalink) Old 02-14-2011, 12:12 PM
PitCritter's Avatar
Originally Posted by rgoulet58 View Post
Will the $600 Optional Tow package give you the extra Leaf spring and 20:1 steering ratio like the Max Tow?
I've looked everywhere I can think of and I can't find any mention of different steering ratio or an extra leaf with Tow or Max Tow. Where did you get this info?
Everything I've read says that the only difference between Tow and Max Tow is the brake controller, an upgraded bumper, and tow mirrors.
An extra leaf makes sense since none of the equipment I've listed boosts GVWR, but I can't find any mention of it anywhere.
PitCritter is offline
post #6 of 6 (permalink) Old 02-18-2011, 02:54 PM Thread Starter
rgoulet58's Avatar
Here is what I found on the US Ford sites in 2010.
Max Trailer Tow Package - $680
Upgraded rear bumper; Trailer towing preparation includes tow hook; Class IV trailer hitch receiver; 7-pin wiring harness; Heavy duty engine cooling system; Auxiliary transmission cooler; Upgraded rear springs (with 18" tires); Heavy Duty front eye bushing; 20:1 steering gear; Requires: [99V] 5.4L Flex Fuel 3V EFI V-8 Engine And [54P] Side Mirrors, Manual Telescoping Trailer Tow w/Power Glass And [X26] Optional Axle Ratio (3.73); Or [XB6] 3.73 Limited Slip Rear Axle.
Thats why I'm wondering about the 2011's Max Tow
13 Esacpe (Wife's)
06 Vulcan 900 LT
05 Brute Force 650
Max Tire Size abwhitetail Super Duty Forum 7 08-14-2010 01:36 PM
Max tow package?? lenny1-2mne F-150 2009 to 2014 Forum 3 10-10-2009 06:39 PM
max trailer tow package Rich06 F-150 2009 to 2014 Forum 9 08-15-2009 03:26 PM
Max tow package capacities kdeacars Ontario 6 05-01-2009 03:05 PM
Ranger Max, anyone? CanadianRanger Ranger Forum 11 03-13-2009 03:29 AM
