2wd in winter - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 09-27-2010, 02:36 PM Thread Starter
2wd in winter
Hello everybody, just purchased my new 2010 Ford F150 XLT 2wd. haven't yet taken delivery but hopefully by the end of the week.
First time owning a 2wd truck since the money isn't there for the 4x4.
What advice or tips does anybody have for driving in the winter w/ 2wd.
So far I have been told the obvious of having a secured weight over the wheels.
I was also told skinnier tires are better to cut through the slush and snow.
Anyways onto my question.
Would the bridgestone blizzaks in the 235/75 be good or is there a better choice?
Any good ideas for the "secured weight"?
Thanks to all for any answers they will be appreciated
Amaroq is offline
post #2 of 15 (permalink) Old 09-27-2010, 03:15 PM
Get actual winter tires And u will be fine. Weight in the box helps. I use 3ft by 2ft patio stones over the Axel. Then u can still use the box. Don't use sand bags they get to be a mess
post #3 of 15 (permalink) Old 09-27-2010, 07:12 PM Thread Starter
Thanks, how do you keep the patio stones secure?
Amaroq is offline
post #4 of 15 (permalink) Old 09-27-2010, 07:46 PM
atk
atk's Avatar
Send a message via MSN to atk
i hope you have those patio stones secured well. worked in wrecking yard for 16 years and seen what can happen when things aren`t secured properly in the box. just thought i would pass this info along....
2004 FORD F-250 XLT 4x4 C/C S/B....
Sct-Livewire with custom tunes, guages, 4" exhaust,coolant filter....soon to be tuned by PHP....
atk is offline
post #5 of 15 (permalink) Old 09-27-2010, 07:50 PM
good info.
im only city driving, so accidents aren't as severe, but i have the rubber bed mat and those puppies ain't sliding anywhere, not saying they would be still there in a accident thou. i have the super crew box and 2 stones side by side were a tight squeeze to fit in between wheel wells. and then a piece of 2x4 against the back wall so they cant fly forward.
post #6 of 15 (permalink) Old 09-27-2010, 08:45 PM
Canadian Tire (and Princess Auto?) sells Shur Trax. Otherwise, get an extra heavy bed mat. A friend who has an older Ranger got one a few years ago from Princess Auto.
I typically used sand bags usually 6 to 8. After a year or two, the plastic bags get ruined to UV and such.
Dave
2010 Ford Ranger FX4
DavidY is offline
post #7 of 15 (permalink) Old 09-27-2010, 09:02 PM
atk
atk's Avatar
just some idea`s....
i usually use railway ties with a 2x8 fastened at each end(tying all ties togetther). 5 will fit between wheel wells (400 to 500 lbs). this is made to fit snug inside the box. this does take up more room , but i usually got ties for free....
if you are going to use patio stone or something similar, make up a woodframe from 2x4 that fits snug inside the box. then lay a sheet of plywood or rubber mat on top and fasten to wood frame.
if you want a really cheap alternitive, fill the bed with wet snow....
as for tires, like stated before, a decent winter tire will work....i have had good luck BFG all terrains for winter use....
atk is offline
post #8 of 15 (permalink) Old 09-27-2010, 09:22 PM
I carried an old foam-filled forklift tire on top of my camper mat in the winter. Tire was 6-700 lbs. Worked awesome. Done the wet snow thing too...equally good...till it freezes! Do you have a "posi" rear? It does help in the traction department. Good studded snow tires are a must if you deal with a lot of ice.
post #9 of 15 (permalink) Old 09-27-2010, 09:27 PM
If you dont mind sharing what type of deal did you score for it? If not congrats anyway.
DASO is offline
post #10 of 15 (permalink) Old 09-27-2010, 11:08 PM
If you're in the city, you probably won't miss 4WD that much. My Mazda's 4WD, but it has a limited slip differential, so I rarely use 4WD -- maybe just in my laneway sometimes when it gets mushy, or to pack down my parking spot.
+1 on what BlairTruck said about regular sandbags. The sand seems to leak out of those woven-type bags and makes a mess. If you go that route, check out a landscaping supplier. You can get bags of sand in heavy solid plastic bags that don't leak. The one near me has ones that are about 80 lb. each and cost $5.
A couple of other things I've used over the years in my old 2WD truck were about 6 dead industrial lead-acid batteries from the recycling skid at our shop. I held them down with tie-downs in the box. They had carrying handles on them, which was convenient, if you needed to move them. Maybe a bad scene if they ever cracked and leaked, but it never happened to me. I probably should have put them in some plastic bins, or something.
I've also filled up Rubbermaid bins with sand and gravel. You can get these big bladder things that you fill up with water, and somehow strap down to the bed. If you wanted to take it out while frozen, that would be a problem, I imagine. I've thought of getting those water bags to weigh down the edges of swimming pool covers. That could be cheaper and more convenient if you wanted to move them. In the spring you could just drain the water, roll them up, and put them away for next year.
Not too worried about sand bags flying around. If I get hit that hard, I'd guess the bags would just burst, and I'd probably have bigger problems to worry about in the hospital ... or no problems at all, in the morgue.
86 Ford F150 302 rclb 2wd Jensen F-150 Pre-1997 Forum 12 11-25-2010 09:57 AM
89 f150 5L AT 2WD Henry Ford F-150 Pre-1997 Forum 2 04-26-2009 09:20 PM
NEED HELP: 89 f150 5L 2wd AT Henry Ford F-150 Pre-1997 Forum 5 04-21-2009 03:09 PM
Let see those 2wd trucks fordtough.ca Truck/SUV Talk 10 08-29-2008 08:12 PM
99 body swap from 2wd to 4wd QWKRN-U Ranger Forum 0 12-15-2007 10:30 PM
