F350 leveling kit install - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 02-01-2009, 01:36 PM Thread Starter
firefighter38's Avatar
Why does Ford build their trucks, Super Dutys anyways, with the front end lower than the rear? New at this so not sure how to attach the images or move what I added in the Albums, so here goes nothing...
firefighter38 is offline
post #2 of 10 (permalink) Old 02-01-2009, 01:50 PM
i think most pickups sit high in the rear, so when they're loaded the ass end sits more level. if they were already level before the load went in, the head lights would be in the trees.
post #3 of 10 (permalink) Old 02-01-2009, 02:01 PM Thread Starter
When I hook up my 5th wheel it hardly moves, unlike my old 2500 Chevy. The rear end sat high and uneven with my 5th wheel. I lifted the front by 2" and now it sits completly level. Makes sense though with what you say. Thanks for the reply.
post #4 of 10 (permalink) Old 02-01-2009, 02:53 PM
BMac's Avatar
x2, they are built like that so when they are fully loaded it will sit level.
Load your pics in something like photobucket, and then use the address inbetween the img tags and it'll show the pic
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #5 of 10 (permalink) Old 02-01-2009, 03:03 PM
Corey, if you go to the pics in your album, there should be a bb code at the bottom of each one. just right click on that and select copy. then click paste in your post and you should have it.
otherwise i can copy them to my comp and post them for you...
post #6 of 10 (permalink) Old 02-03-2009, 01:15 AM Thread Starter
I'll give it a shot, thanks!
post #7 of 10 (permalink) Old 02-03-2009, 01:24 AM Thread Starter
Perfect, it worked thanks!!
post #8 of 10 (permalink) Old 02-03-2009, 02:05 PM
BMac's Avatar
Looks good!
BMac is offline
post #9 of 10 (permalink) Old 02-03-2009, 02:49 PM
with the lifting blocks you might what to get extended length shocks so you will get full suspension travel.
post #10 of 10 (permalink) Old 02-03-2009, 03:54 PM
zip
zip's Avatar
Some kits recommend shocks and others don't. When I put mine in I put in 4 new shocks as well.
Chris
75 F150, 79 Bronco
zip is offline
Leveling kit? E36er Suspension 79 06-05-2009 07:37 PM
EVERYTHING YOU WANT TO KNOW ABOUT LEVELING KITS tohi2care F-150 2004 to 2008 Forum 0 01-25-2009 03:45 PM
Icon or Bilstein leveling kit duckdog F-150 2009 to 2014 Forum 6 11-15-2008 02:09 PM
Leveling kit and tires installed! ScottyV Truck/SUV Talk 22 11-14-2008 03:34 PM
CD install Umaxman Audio and Electronics 11 05-11-2008 11:09 AM
