Frozen windshield washer nozzles - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 02-06-2016, 11:46 PM Thread Starter
quick98gtp's Avatar
Had this problem a few times now. Started the same day I put my new headlights in so I figured I may have disconnected something accidently when putting the heqdlights back in..Took the headlight back out and wiggled the hoses and it started working..just a coincidence as the nozzles had thawed while in the garage. Researched this and found its a commen problem. Anyone else on the forum had this issue? ( and I read it's not actually the nozzles it's something in the lines, regardless it's still fucked)
Other than this small issue the trucks been a dream so far!
quick98gtp is offline
post #2 of 11 (permalink) Old 02-07-2016, 10:28 AM
Am I reading that right? I did not know the 2015's had windshield washer nozzles for the headlights.
post #3 of 11 (permalink) Old 02-07-2016, 12:30 PM Thread Starter
quick98gtp's Avatar
Nope the thread title Cleary states "frozen windshield washer nozzles"..the washer fluid reservoir and pump are directly behind the passenger side headlight so thought I may have hit something accidently on re-assembly.
post #4 of 11 (permalink) Old 02-07-2016, 12:37 PM
Alright, so I didn't pay much attention to the thread title, granted, but the way the post is written its easy enough to make the mistake that the headlights have washer nozzles.
Thanks for clearing that up, now I get it, never had that problem, but I've got a '14.
post #5 of 11 (permalink) Old 02-07-2016, 10:19 PM
CDM76's Avatar
Yep, they've frozen on me three times now. Twice on the highway. Thought it was just me .... Really regretting buying this truck.
CDM76 is offline
post #6 of 11 (permalink) Old 02-07-2016, 10:36 PM
not the washer, just the door locks
ron4400 is offline
post #7 of 11 (permalink) Old 02-07-2016, 10:44 PM
I like Fords Too's Avatar
is there a way to add a length of washer hose to what comes from the washer res so that you could wrap the extra length of hose around a rad hose or trans line or even just somehow attach the hose to the rad tank to wick some heat into the washer system ?
if you could do this at a point lower than the res jug it would send heat to both the res and pump as well as the rest of the washer system
I like Fords Too is offline
post #8 of 11 (permalink) Old 02-08-2016, 09:05 AM
Starting to hear lots of odd issues with the 2015's, not good.
Is it the nozzles or is the actual tank full of fluid freezing too?
Don't want to sound like captain obvious but it's got winter wash in it right?
post #9 of 11 (permalink) Old 02-08-2016, 11:26 AM Thread Starter
quick98gtp's Avatar
Yep, winter fluid. I'm defenitly not regretting buying this truck that's for sure! First production year always has little kinks, not expecting an issue but not surprised.
post #10 of 11 (permalink) Old 02-08-2016, 12:56 PM
Canadian Bacon's Avatar
It's not Fords crappy "winter" fluid is it?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
E-brake frozen? Cold Temps. HotShotMedic Ranger Forum 5 02-14-2012 04:40 PM
howdy from the frozen north shelbyx1 New Members Introductions 19 10-11-2008 08:24 AM
