Factory remote question. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 6Likes
  • 1 Post By SVT4MT
  • 2 Post By Destructicon
  • 1 Post By blackford1157
  • 2 Post By SVT4MT
post #1 of 5 (permalink) Old 02-02-2018, 12:52 AM Thread Starter
blackford1157's Avatar
I have a 2016 ford f 150 super crew. This truck is still very new to me.I set the fan control to hi and hi heat setting before I shut my truck off (with the the key). Then in the morning when I go to start it up via remote. When I jump in the fan setting is as low a it could be and not really very warm for running for 10 mins or so. So I'm thinking that this is a factory default,set in the remote start system of my truck . My question is can this be changed???
Thanks Guys
Dan
blackford1157 is offline
post #2 of 5 (permalink) Old 02-02-2018, 05:17 AM
I believe theres a screen you can access and set up the remote start parameters , how high you want the fan, whether or not the heated seats come on etc.
Have a look in the settings, I don't recall off the top of my head where it is, but it rings a bell with the setting it up to your liking.
blackford1157 likes this.
post #3 of 5 (permalink) Old 02-02-2018, 06:24 AM
I believe the screen is in the middle of the dashboard.
Fordsforever6.0 and SVT4MT like this.
post #4 of 5 (permalink) Old 02-02-2018, 09:39 PM Thread Starter
I was thinking at first there might be a problem with the truck. It only occured when I remote started it. Once i manually started it the fan would go to were I set it before. So I figured it had to be a default. My older ford has no fancy things like this new one. I was just going thru the 507 page manual for my truck and on page 145 there is a remote start setting section
Thanks SVT4MT.
Dan
Mrmagoo likes this.
post #5 of 5 (permalink) Old 02-03-2018, 10:04 AM
Twisted sense of humour and other gifts as well.
Destructicon and Mrmagoo like this.
factory remote start install help needed wingdreamer F-150 2009 to 2014 Forum 0 01-20-2015 04:32 AM
Remote Starter TRUKNUT Audio and Electronics 16 12-28-2013 12:25 AM
Factory remote start danr F-150 2004 to 2008 Forum 8 02-12-2013 09:46 PM
NEED HELP: Remote start question thepike F-150 2009 to 2014 Forum 2 09-28-2011 12:37 AM
Remote starter brauner_1 Audio and Electronics 1 12-16-2008 04:35 PM
