Correct Payload Capacity?? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 01-26-2019, 06:23 PM Thread Starter
Exclamation Correct Payload Capacity??
Im adding a 2019 F250 platinum diesel for RVing and keeping my 2015 F150 for my daily driver. On the F250 drivers door the sticker says Max Payload is 1963 pounds. The dealer provided a specs printout based on my VIN which shows 2670 pounds. Are both referring to the same thing or what is the difference? Im looking at a fifth wheel with a pin weight of 2000 pounds so I really need to understand which number is correct to determine if I safely pull my desired RV. Fifth wheel towing capacity of 14700 pounds is no problem, just the payload needs some clarity. Thanks.
OrangeTurbo is offline
post #2 of 2 (permalink) Old 01-27-2019, 06:15 AM
Driver's door sticker is the absolute value. It's the one the Ministry looks at when the pull you over because they suspect you've overloaded your truck. It's the as built specification. The VIN number database that everyone looks at is not always correct. You will have to compensate by checking wheel bearings, tires, suspension, and brake capacity for increased weight capacity. You should have, at least, 10% more capacity than actual load. Even then, I would personally consider that too light. You should consider an F350.
Any other HD Payload Package owners on here? RyPow F-150 2009 to 2014 Forum 2 03-20-2015 10:24 AM
NEED HELP: Tow Capacity FawkinFords F-150 2009 to 2014 Forum 3 12-07-2011 07:03 AM
1992 F450 Super Duty front axle capacity needed GinNB Super Duty Forum 4 04-16-2010 01:40 PM
How to correct the tire size in the computer Bruicer Wheels and Tires 3 09-02-2008 04:48 PM
