Make your F150 more functional with Putco Venture TEC Rack + Rebate - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 04-09-2020, 05:24 AM Thread Starter
Site Sponsor
CARiD's Avatar
There is no need to describe the value of a durable and functional bed rack for a truck owner. If you're on the market for this kind of upgrade for your Ford F150, make sure to look at Putco's Venture TEC Modular Cargo System. Constructed using aluminum-extruded tubing, it has a distinct look as well as unparalleled functionality.
It can be easily mounted to any truck in two ways - using stake pocket mounts on trucks with stake pockets and using OEM hardware on a rail system for non-stake pocket trucks. It is also compatible with tonneau covers so that you can have both wet and dry storage.
Update your F150 with this high-quality Venture TEC Rack today and get $150 back in your pocket. The offer is valid until May 15, 2020. Please check the PDF form to get your reward.
Putco® - Venture TEC Rack
Features:
  • Lightweight and strong all 6061 T6 Aluminum construction
  • Pass through channel for in-stanchion wire routing
  • CNC 7 axis bending for exact vehicle cab contour
  • TEC channels for accessory modifications
  • No Drill Installation stake pocket
  • High Impact durable black powder coat finish
  • 500lb tie-down strength
  • Compatible with all Putco TEC accessories (Tie Downs, Hand Grips, Light Bars)
  • Designed, engineered and manufactured in the USA by PUTCO INC.
  • Putco exclusive patent pending extrusion tube
  • Works with all modern tonneau covers
Ford Specialists http://www.carid.com/ford-accessories/
Call Toll Free: 800.505.3274 | Facebook | Twitter | YouTube
CARiD is offline
