truck died suddenly while going down the road like someone turned the key off. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 04-17-2011, 08:39 AM Thread Starter
Was driving down the road and my truck just died suddenly like someone shut the key off. got power to positive side of coil but none to negative side of coil. checked power at pin 8 of wire from distributor and no power so the stator or pip doesn't seem to have power. would this be a bad pip sensor.
The Rumble Beast is offline
post #2 of 7 (permalink) Old 04-17-2011, 08:43 AM
Welcome to fordtough.ca - haven't got any suggestions for you Rumble Beast, but plenty of experience and knowledge here.
Should have some info in no time at all.....good luck and here's hoping for a quick fix.
post #3 of 7 (permalink) Old 04-17-2011, 09:32 AM
what year is your truck? Also what motor?
post #4 of 7 (permalink) Old 04-17-2011, 10:03 AM Thread Starter
its a 1992 and has the 302 motor.
post #5 of 7 (permalink) Old 04-18-2011, 06:53 AM
Have a look at the ignition switch. While I haven't had this problem, apparently they can be a problem. Did you test the ignition coil with reference to ground? Specifically the negative terminal.
post #6 of 7 (permalink) Old 04-18-2011, 05:24 PM Thread Starter
well i was testing for the injectors pulsing today and the truck started right up. changed the cap and rotor on truck 3 or 4 days before and cranked truck over and wouldn't start then left truck for a few days and was check coil positive and negative yesterday and negative side had no power when truck turned on and when cranking. not sure what would make my truck start all of a sudden today. i tried a to start it 7 or 8 different times today and truck started everytime.
post #7 of 7 (permalink) Old 04-18-2011, 06:21 PM
check both the positive and negative wires going to the coil for as long as you can trace them. My 96 died on me going down the road one day, had her towed home. Checked for spark and had none. So I went to swap out the coil and when I pulled the connector out saw that the negative wire had broken about 3 inches up from the plug. Spliced and soldered new wire in and she was good as new
Jim
NEED HELP: truck died OneTomcat F-150 2004 to 2008 Forum 2 03-08-2010 09:06 AM
Battery Died haywire F-150 2004 to 2008 Forum 3 02-14-2010 01:19 PM
Ready Lift torsion key lift Ford00XLT F-150 1997 to 2003 /04 Heritage Forum 6 01-16-2010 10:33 PM
NEED HELP: It just died.... Alternator? Jensen Gas Engines 3 11-28-2008 09:53 PM
