NEED HELP: Thermostat removal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 03-27-2012, 04:03 PM Thread Starter
Thermostat removal
How in the F*ck are you supposed to get the bottom bolt, there is no clearance for any socket of any kind even with an elbow. A wrench is to long to turn, I mean why do they build sh*t like this?
Any ideas? Is there some special tool I'm not aware of?
fordx4 is offline
post #2 of 10 (permalink) Old 03-27-2012, 07:44 PM
4.9L or V8?
post #3 of 10 (permalink) Old 03-27-2012, 07:51 PM Thread Starter
v8, 302, guess I need a stubby wrench or an angled one
fordx4 is offline
post #4 of 10 (permalink) Old 03-28-2012, 11:56 AM Thread Starter
Well I finally got it out, for anybody else that does this in the future you will need a shortie wrench.
Does anybody have any idea if you can tell if a thermo is bad by looking at it? The problem I was having was that the coolant was cycling as soon as I started the truck, so I assume it was stuck open. But it looks fine.
fordx4 is offline
post #5 of 10 (permalink) Old 03-28-2012, 01:45 PM
Part is cheap just replace it
post #6 of 10 (permalink) Old 03-28-2012, 03:35 PM Thread Starter
i did replace it, was just curious.
fordx4 is offline
post #7 of 10 (permalink) Old 03-29-2012, 08:23 PM
smokeshow's Avatar
I was going to post I got mine out not long ago with a shorty but I see you've figured that out lol.
smokeshow is offline
post #8 of 10 (permalink) Old 03-29-2012, 08:35 PM
There is a bypass. A GM distributor wrench worked for me. At least, it worked on the '76.
post #9 of 10 (permalink) Old 03-29-2012, 09:57 PM
The best way to test a thermostat is to drop it in a pot of water and bring it to boil. Watch the thermostat and see if/when it opens and closes.
chrmar is offline
post #10 of 10 (permalink) Old 03-30-2012, 07:10 PM
Use a thermometer while boiling it so you can see what temperature it's opening. Very important point!!! Don't use the better half's good cook ware to do this.
Box removal xllxll_VIPER_llxllx F-150 1997 to 2003 /04 Heritage Forum 22 05-27-2010 08:05 PM
Panel Removal macs07 F-150 2004 to 2008 Forum 2 01-20-2010 07:45 PM
Thermostat question? Silver FX4 F-150 2004 to 2008 Forum 9 06-25-2009 02:19 AM
Headlight Removal??? white4by4 F-150 2004 to 2008 Forum 5 02-05-2008 11:40 PM
battery JB wiring removal?? lightning25 Audio and Electronics 1 08-28-2007 08:55 PM
