NEED HELP: Freakin BRUTAL!! - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-28-2012, 10:37 PM Thread Starter
smokeshow's Avatar
Freakin BRUTAL!!
Motor is torn apart...
anyone ever seen this.
cylinder 1 - 4
http://youtu.be/abkHC27fOo0
cylinder 5 - 8
http://youtu.be/npLQZzXh3Io
top of 1-4 head is covered in black
top of 5-8 head is quite clean considering... not too sure what to make of all this. timing? injectors? dizzy pooched?
smokeshow is offline
post #2 of 6 (permalink) Old 03-29-2012, 03:23 AM
How many 02 sensors on your truck?
post #3 of 6 (permalink) Old 03-29-2012, 07:07 AM Thread Starter
smokeshow's Avatar
1, it sits centered between the 2 sides on a Y pipe to single exhaust.
truck was throwing codes 412, 126 and 538 when it was hooked up to a reader and doing the engine test.
post #4 of 6 (permalink) Old 03-29-2012, 08:42 PM
I saw that once on a carbed engine. The oil drains were clogged up and the oil level came up over the valve seals.
post #5 of 6 (permalink) Old 03-30-2012, 05:56 AM
What engine?
2008 F150 FX4 SCAB : BLUE STREAK
She's gone but never forgotten! Replaced with a blown:
2008 F150 FX4 SCREW : SILVER BULLET
Ross is offline
post #6 of 6 (permalink) Old 03-30-2012, 10:27 AM Thread Starter
smokeshow's Avatar
5L on a 94
6+ freakin' months to find the problem!? 04STXHERITAGE F-150 1997 to 2003 /04 Heritage Forum 8 09-16-2009 07:18 AM
