Small miss and airlock in cooling system - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 04-01-2012, 02:31 AM Thread Starter
Just did a quick tuneup to my truck. It had a rough idle and was lacking power
Changed manifold gasket and fixed leak at manifold to exhaust
Changed Spark plugs, wires, dist cap, and rotor
The truck idles and runs better but still has a slight miss
The thing that worries me is that I reconnected the valve cover to airbox hose (previous owner unhooked)and it is getting gummed up with yellowish froth and froth in the oil cap
At first I thought the worst, head gasket, but no froth in oil, coolant level never went down.
Then I thought blowby but there is very little smoke coming out of the oil fill, and no pressure coming out of the cap
Any ideas
Second I changed the thermostat and have a very annoying air lock. I tried letting it reach normal operating temp at idle, squeezing the rad hoses, heat on, heat off etc.
The truck never heated up past normal range but while driving it heats up almost to red then immediately drops back down to normal. The fluid in the overfill stays cold so it is not cycling. I was told by a buddy to leave the rad cap unlocked, while going for a short drive, not off, just not sealed and allow it to boil over . Do you think this will work?
I also want to seafoam the truck, I should have done it b4 the tune up. But it should be ok, I've heard it can foul plugs, but I doubt theres any truth in that. Any feedback?
fordx4 is offline
post #2 of 9 (permalink) Old 04-01-2012, 02:54 AM
Make sure none of your plug wires are crossed close as this can cause spark jump which will cause a miss.
Second no need to take the truck for a drive to get rid of the air lock. You can do it idling in your driveway with the rad cap off.
post #3 of 9 (permalink) Old 04-01-2012, 08:05 AM
I use Seafoam in my bikes every 3rd or 4th tank of fuel. It keeps the fuel system spotless including the carbs/jets. I haven't experienced any issues with the plugs.
post #4 of 9 (permalink) Old 04-01-2012, 10:47 AM Thread Starter
It doesnt seem to ever reach the airlock while its sitting in the driveway. I let it run for about 15 minutes with the cap off but I never puts coolant into the overflow.
fordx4 is offline
post #5 of 9 (permalink) Old 04-01-2012, 11:41 AM
If you hear it gurgling at the heater core you will probably have to raise the front end and do it that way. 15 minutes will not be enough and make sure you squeese the upper hose lots.
post #6 of 9 (permalink) Old 04-01-2012, 09:53 PM
With the rad cap loose, You won't get coolant overflow right away. When the thermostat opens, the air should get pumped into the radiator. At this point, add more coolant. Make sure it's not ice cold. Stick it on top of a heat vent from the furnace or something. Don't microwave it. It will need longer than 15 minutes idling in the driveway. You may have an injector not firing right which may cause a miss. O-rings on the injectors may need changing.
post #7 of 9 (permalink) Old 04-01-2012, 10:04 PM Thread Starter
has anyone ever experienced blow by with a 5.0. There is a little smoke coming out of the oil fill but not enough to knock a loose cap off like most blow by
fordx4 is offline
post #8 of 9 (permalink) Old 04-01-2012, 11:05 PM
Never experienced it on my 5.0. Have you checked your PCV valve?
post #9 of 9 (permalink) Old 04-02-2012, 09:11 AM Thread Starter
yup replaced it, seems to be functioning fine. I wish I had've seafoamed it b4 I did everything else. I dont want to take the chance that it will foul my plugs. The inside of the valve cover is gooped up pretty good. Black tarry stuff.
fordx4 is offline
Miss TMP - Labour Day Weekend at the Track TMPracing Ontario 0 08-07-2009 05:42 PM
NEED HELP: Oil in cooling system? patchwrx Diesel Engines 5 05-30-2009 01:30 PM
strange miss...low grade misfire of TCC? dalman Driveline and Transmission 0 02-18-2008 06:20 PM
