not dropping high idle (warm up) - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 05-29-2012, 03:01 PM Thread Starter
smokeshow's Avatar
truck is idling around 2grand on warm up but it isn't going down to a proper idle once it's warm. where to start?
smokeshow is offline
post #2 of 11 (permalink) Old 05-29-2012, 03:24 PM
Ol Skool's Avatar
It sounds like the throttle position censor. Have the codes read, that should tell you allot.
Gerry
Ol Skool is offline
post #3 of 11 (permalink) Old 05-29-2012, 06:09 PM
Which engine size? Which year and model?
post #4 of 11 (permalink) Old 06-07-2012, 08:25 PM Thread Starter
smokeshow's Avatar
95 flare side, 5 spd, 5L stang engine.
post #5 of 11 (permalink) Old 06-07-2012, 09:40 PM
Throttle position sensor or auxiliary air bypass if it has one.
post #6 of 11 (permalink) Old 06-07-2012, 11:29 PM Thread Starter
smokeshow's Avatar
that auxillary bypass... is that the electric choke unit on the side of the TB?
post #7 of 11 (permalink) Old 06-08-2012, 03:12 AM
TPS reading off the green center wire should be .97v anything ove 1v and your ECU will be running in open loop mode
post #8 of 11 (permalink) Old 06-08-2012, 03:19 AM
truck or stang intake and throttlebody?
post #9 of 11 (permalink) Old 06-08-2012, 11:49 AM Thread Starter
smokeshow's Avatar
it's got the truck intake on it until I get around to swapping the blower on it.
post #10 of 11 (permalink) Old 06-08-2012, 03:57 PM
Check for vacuum leaks around the in takes
High idle mod Barnyardford F-150 2004 to 2008 Forum 6 01-30-2012 06:45 PM
97 high idle stalls LayinHp F-150 1997 to 2003 /04 Heritage Forum 11 03-11-2010 08:11 AM
WARM mitchykins Alberta 16 03-10-2009 06:58 PM
NEED HELP: high idle CKM Ranger Forum 8 12-08-2008 11:31 PM
