NEED HELP: Installing a Lower Seal Kit on a Steering Gear - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 03-13-2013, 07:44 PM Thread Starter
kidd's Avatar
I have been looking and from what I see so far there is a inside lock ring that I have to remove along with a dust cover and a seal after I remove the pitman arm. I am to also check for any scoring or rust on the actual shaft, does this about sum it up, also I am hoping this can be done with the steering box still attached to the frame, any input would be appreciated
13.32 @ 99.79mph
60' @ 1.86
www.kdracingteam.com
kidd is offline
post #2 of 5 (permalink) Old 03-13-2013, 08:03 PM
Ol Skool's Avatar
Usely the Pitman shaft is scored or grooved. Thats why they leak. Rebuilt steering boxes arn't too expensive. That's the way I'd go. The outer seal on the pitman shaft is only the first step. There is two "O" rings behind it that hold the pressure. If it's leaking, You need a rebuild kit, not just a seal.
Gerry
Ol Skool is offline
post #3 of 5 (permalink) Old 03-13-2013, 10:06 PM Thread Starter
kidd's Avatar
Thanks Gerry, for the quick response, guess will be looking at a steering box, about $301.00 re manufactured or so. The states side about $147.00.
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
post #4 of 5 (permalink) Old 03-14-2013, 04:32 AM
shop around for a better price in ON.
from my experience on the 1980- 1996 ish steering boxes removing from the truck is a better way to reseal the output. sounds like a lot more work but its not nearly as aggrevating! if you go with the seal kit pack as much grease into the area as possible, prevents crap contamination and will make the new seal last much longer.
big truck steering boxes come with grease fitting between the inner and outer output shaft seals for a reason
I've had bad experiences with reman boxes. they are usually over adjusted (too tight!) and should not have been rebuilt with the existing sector shafts.................
good luck
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #5 of 5 (permalink) Old 03-14-2013, 07:13 AM
Ol Skool's Avatar
James, I've had problems with one. After that, I adjusted the gear lash once I installed it. I've had no problem since.
Gerry
Ol Skool is offline
NEED HELP: Installing Clearance Lights on 08 tjpete Super Duty Forum 1 09-03-2010 11:34 AM
How to: Rear Axle and Pinion Seal replacement (7.5 ring gear) jdcrush Ranger Forum 8 08-22-2010 02:56 PM
NEED HELP: Trouble installing 2.5" leveling kit rwnolan F-150 2004 to 2008 Forum 23 07-23-2010 02:07 PM
Help installing a sub? BCwheeler F-150 2004 to 2008 Forum 9 02-19-2010 03:23 PM
