77 f150 steering column swap. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 07-12-2015, 02:12 AM Thread Starter
I have a 77 f150 automatic column shift, and I would like to swap it for a 78 tilt column. I understand the neutral safety switches are in different locations. any other differences that would prevent this swap from working?
khoule is offline
post #2 of 3 (permalink) Old 07-12-2015, 08:04 AM
There shouldn't be any differences unless they moved the neutral safety switch from the column to the transmission.
post #3 of 3 (permalink) Old 07-12-2015, 03:08 PM Thread Starter
Thank you for the info. I know the 77 has the neutral safety switch in the column. 78/79 have the switch on the transmission. If this is the only difference between the columns I can make it work.
khoule is offline
troubleshooting steering problems for 99 f150 h20fella F-150 1997 to 2003 /04 Heritage Forum 2 01-06-2010 02:46 PM
NEED HELP: 2002 f150 won't start unless steering colum is down HOTDOG Gas Engines 2 12-05-2009 06:10 PM
NEED HELP: Steering column diagram DragonArm British Columbia 1 08-09-2009 12:35 AM
Clunking in steering column! Chienlaid Ranger Forum 8 04-11-2009 11:29 AM
STEERING COLUMN TRIM MOD. THE H.P FREAK Sticky Tech/How to Section 9 01-20-2009 07:55 PM
