NEED HELP: Old 400 CID engines - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 08-04-2015, 10:06 AM Thread Starter
Old 400 CID engines
Good Morning. I would like to know where to fine info on 400 CID engines used in the late '70s. My '76 has the label 351/400 M but my neighbor's '79 is labelled 400 EGR. The M series engines were notorious for bad cranks. Did Ford improve them and change the labelling on the later engines? Thx in advance.
rrobblee1 is offline
post #2 of 5 (permalink) Old 08-04-2015, 11:54 AM
Google is your friend. There is lots of info out there. Their cranks were no weaker than anything else out there. They all need oil. There were different emission systems used on them so different labels. I had a 78 Bronco with 400 with 351C 4v pistons, Edlebrock Peformer intake, Crane RV cam, Hooker headers. Had to put bushings in con rods to make up for different pin size but when done it would out pull most 460 engines. 9mpg empty or pulling 10,000 lb trailer. Mega torque at low rpm from the 400 if set up right.
post #3 of 5 (permalink) Old 08-04-2015, 12:33 PM
cranks were not the problem. poor quality bearing right out of the gate.
not many 400s with original bearings in them any more. 400 is an under rated engine that can produce lots of torque. and with a 4 barrel aftermarket intake can keep up with a stock 460, with a little less weight.
not sure on the egr designation but I'm guessing that your neighbors engine is either in a car or an F100,
yours is probably from an F150-F350. lighter vehicle had stricter emmisisons.
does yours have an egr on it?
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #4 of 5 (permalink) Old 08-04-2015, 03:56 PM
I haven't heard of the 400 EGR... but have heard of the 400 EFI's... if your on facebook theres a couple of groups on the 73-79 f-series these guys know there stuff
post #5 of 5 (permalink) Old 09-11-2015, 12:29 PM
I like Fords Too's Avatar
I know my 76 460 truck motor was no air pump , no egr
my 76 460 ltd station wagon motor was an air pump / egr motor though
so what it originally went into makes a bit of a difference
my 79 302 half ton was a non catalitic exhaust but my buddy's 80 was
though an 81 one ton was still non catalitic
I like Fords Too is offline
thinking of changing engines gilligan F-150 1997 to 2003 /04 Heritage Forum 13 11-19-2012 03:33 AM
Torque curves of the new engines Northern Supercrew F-150 2009 to 2014 Forum 11 04-19-2011 06:07 PM
EcoBoost engines in F-150 by 2010 fordtough.ca F-150 2009 to 2014 Forum 2 08-19-2008 09:41 AM
Ford Engines Firing Order fordtough.ca Sticky Tech/How to Section 0 01-02-2008 12:45 AM
