Vibration - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 12-04-2015, 10:53 PM Thread Starter
Vibration
I have this vibration when coming from the rear area and can't seem to pin point it. When at higher speeds it's good, and lower speeds it's good. Just when the train kicks into 3rd I believe, but when it starts and if I give it more gas it's goes away, and if I lay off the throttle it's goes away.
History as of a week ago that's when I bought it.
1.Transfer case had a hole in it, so it could have ran dry, more then likely did. So would a barring, or chain in the tcase cause this?
2. Rear end was almost dry due to seals. Maybe a pinion Barring ?
All of which are tight with no play, and all ujoints are good. Have not popped the rear plate off yet.
Thus truck has the electric trani in it so would a bad battery cause the trani to struggle under load?
Sorry for the thousand question.
1995 F150 4X4 5.8L
Cheers
Ujoint is offline
post #2 of 10 (permalink) Old 12-04-2015, 11:21 PM
I'd say you're on to something with the t-case and rear-end both running low on fluid.
post #3 of 10 (permalink) Old 12-05-2015, 04:42 PM
Do you have a hanger bearing? Have you checked the axle shaft ends for true? Are the axle shaft bearings tight?
post #4 of 10 (permalink) Old 12-06-2015, 07:48 AM Thread Starter
They seemed tight when I had the wheels off, but I have not opened it up yet. What's a hanger barring ?
Ujoint is offline
post #5 of 10 (permalink) Old 12-06-2015, 12:15 PM
Some trucks have a hanger support bearing that supports the driveshaft. If the bearing is bad you will get vibration.
post #6 of 10 (permalink) Old 04-30-2016, 04:21 PM Thread Starter
So little update. I drained the oil from my transfer case that I put in about 6000K ago and it was very red, darker then blood . And rotated the tire with my ear to TC and there is a wine sound coming from the TC. The atf was plain and color going in. There is a little play from the Out put shaft (rear) .
History on TC . Was a hole when I got it , but fixed the hole. So there's no telling how long it was like that, or how many times was ran dry. So with possible eternal damages ,bearings, stretched chain, etc. Would y'all think that at high RPMs that would cause a surging/ vibration? And sometimes very noisy.
Trani seems good, OD light don't flash or no slippage when this is happening .
Ujoint is offline
post #7 of 10 (permalink) Old 05-01-2016, 07:57 AM
Replace the t-case. Good time for an NP205 conversion.
post #8 of 10 (permalink) Old 05-01-2016, 08:32 PM
BW 1345 will come out in your hands, NP205 you will need a jack. unless you have a strong friend
there was a reason the 205 came with a frame mount on the side!
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #9 of 10 (permalink) Old 05-01-2016, 09:45 PM
Yes, but the nice part is you'll probably never have to worry about it for a really long time.
post #10 of 10 (permalink) Old 05-02-2016, 06:18 PM Thread Starter
Cool see what I can get my hands on. The 205 the s the gear driven, was in Chev's earlier if I remember correctly? And ya if so they are effing heavy.
Ujoint is offline
Vibration Beans F-150 2009 to 2014 Forum 25 08-02-2013 09:37 AM
Vibration Again.. quick98gtp F-150 2009 to 2014 Forum 7 11-26-2012 08:37 AM
vibration bootman F-150 2009 to 2014 Forum 10 08-24-2012 08:52 PM
NEED HELP: Vibration Ranger Danger Ranger Forum 10 12-07-2010 09:17 PM
seatback vibration bushboots F-150 2004 to 2008 Forum 6 10-17-2008 08:42 PM
