Lost D, and speedo stoped working - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-28-2015, 01:02 AM Thread Starter
Hey guys merry Christmas
So this is what happened. Truck has sit for a wile in the cold, and when I was driving it this afternoon I lost D. And the speedo stopped working. But I had 4wd, 2ND, and 1St . Checked the fuses they seemed OK. Then when I got back on the road D worked but speedo was all erratic.
1995 F150 4wd 5.8L and it's the electric train
Ujoint is offline
post #2 of 7 (permalink) Old 12-28-2015, 01:02 AM Thread Starter
Electric trani I mean
Ujoint is offline
post #3 of 7 (permalink) Old 12-28-2015, 08:01 AM
Try the speed sensor in the rear axle. It's a cheap easy fix and it operates your speedometer. That may clear both issues.
post #4 of 7 (permalink) Old 12-28-2015, 09:49 PM Thread Starter
Ya I will for sure. Thanks
Ujoint is offline
post #5 of 7 (permalink) Old 12-28-2015, 11:00 PM Thread Starter
I guess I should ask is there anything special about replacing these? Need to knows...
Ujoint is offline
post #6 of 7 (permalink) Old 12-29-2015, 06:51 AM
Not really, make sure you clean the dirt and corruption from around the sensor before removing it. You wouldn't want that getting into the differential. I had no problem doing mine. Undo the plug and bolt, then pull it out. Lube the new one with some axle grease or 80W90 oil before inserting the new one. Don't forget to disconnect the battery for a few minutes. Then reconnect it and go for a 10~15 minute drive. While you're under there, check your differential oil level. I found that a couple of light taps with a ball peen hammer on the bolt head prior to removal helps to loosen it.
post #7 of 7 (permalink) Old 01-07-2016, 10:12 PM
Fuse # 17? Bad shifter?
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
Speedo/Odo Question Blue Oval Driveline and Transmission 9 08-19-2012 03:09 PM
LOST??? iwannaplay Ontario 20 12-15-2011 04:55 AM
Speedo reset T1bird Ontario 5 10-30-2011 08:37 PM
NEED HELP: Changing speedo gear on 97 f150 f150phule Driveline and Transmission 4 10-20-2009 12:29 AM
Speedo gear help SKRWZ Wheels and Tires 0 12-10-2007 12:00 AM
