Fuel tank rear - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 05-04-2016, 09:18 PM Thread Starter
Fuel tank rear
Removed the rear tank for the day until I get a gasket for it, and the return line can it be pinched off or what ? I'll be driving the truck tomorrow as it is
Cheers thanks
Ujoint is offline
post #2 of 8 (permalink) Old 05-05-2016, 06:16 AM
If I recall correctly, I used a short piece of hose with a bolt clamped in it.
post #3 of 8 (permalink) Old 05-06-2016, 09:33 AM Thread Starter
But what's the deal with this, you suck from one tank and it returns to the other? WTF unless something is not working right
Ujoint is offline
post #4 of 8 (permalink) Old 05-06-2016, 02:19 PM
if you are sucking from one tank and its returning to the other your dual tank switch if fooshnicken.
should be able to run with one tank removed as long as you have your switch on the remaining tank.
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #5 of 8 (permalink) Old 05-06-2016, 07:10 PM
That year should have dual fuel pumps. So, if one tank pumps into the other than you have a bad fuel pump(s). Or screwed up connections.
post #6 of 8 (permalink) Old 05-11-2016, 11:12 PM Thread Starter
OK Hummmm. Both pumps work fine. And when you said switch, you mean the switch on the dash, or is there a switch / junction on the inside frame rail.
Ujoint is offline
post #7 of 8 (permalink) Old 05-12-2016, 05:53 AM
Older trucks used to have a tank switching solenoid valve on the frame rail. This was controlled by a switch on the dash. Yours has two fuel pumps. One in each tank. The fuel return line is controlled by a valve inside the fuel pump housing which is operated by pressure from the fuel pump. If the pump is on and working the valve is open allowing fuel to return. Of course, if the pump is off or not working the valve will not open and fuel is blocked from returning. In case anyone is wondering, I had to change my front pump and I was curious, so, I opened up the old one to see how it worked.
post #8 of 8 (permalink) Old 05-13-2016, 12:20 AM Thread Starter
Right on. Thanks for the info.
Ujoint is offline
NEED HELP: additional fuel tank herlinde marc Gas Engines 0 05-10-2015 09:26 PM
2012 xlt no fuel tank protection??? mmgg F-150 2009 to 2014 Forum 0 09-28-2014 04:24 PM
Fuel Tank Strap Recall SCrew Lariat F-150 1997 to 2003 /04 Heritage Forum 38 06-01-2012 03:30 PM
