signal light lens- 94 F-150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 05-12-2008, 03:12 AM Thread Starter
anyone changed signal light lenses on 94 F-150's?....you have to remove the headlight housing except for the headlight itself?...there are two screws up under the hood, but there is still something holding the housing in place under the lens area, and over under the headlight....did not see anything obvious.
Bill
truckguy94 is offline
post #2 of 2 (permalink) Old 05-17-2008, 08:54 PM
There is a screw on the outer side where the housing meets the front fender, it is impossible to get at unless you remove the whole headlight assembly which is a real PITA. There is 2 bolts on the back side of the headlight which are hard to see, just feel around with your fingers till you find them. they are easy to get out but a pain to get back in, good luck.
bluebomber94 is offline
light bar for rollbar Lilbigtrk Lighting 4 04-17-2008 04:00 AM
Left Turn Signal on When breaking PMarch Ranger Forum 23 12-28-2007 03:40 PM
Are you looking for colored light bulbs fordtough.ca Lighting 2 12-20-2007 10:17 PM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 09:21 PM
