Intake Manifold gasket tip (?) - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 09-27-2008, 10:23 PM Thread Starter
Thought I would pass this along.... at stop lights, my oil pressure gauge would drop to the bottom of the acceptable range; I would shift the truck into neutral and the rev's would jump up and the pressure would come back....went like this for a couple of months because I had a cold idle problem and thought it was related to the Idle Control in the throttle body....put off the repair because it was summer and the cold idle was a minor issue.... also had an oil leak and took the truck in to have the oil leak fixed....they tracked the main leak, using dye, to the intake gaskets (and timing chain cover gasket, too), replaced them, and lo and behold, the oil pressure is totally stable ...never guessed the intake was an issue... fyi
Bill
truckguy94 is offline
post #2 of 2 (permalink) Old 09-28-2008, 02:34 AM
Important Tip for 5.4 owners Blackstock F-150 2004 to 2008 Forum 41 01-07-2012 02:20 PM
Airaid Intake Matty Ranger Forum 7 04-07-2008 09:50 PM
Intake For 07 v6 stx STXPrincess Ranger Forum 6 03-16-2008 07:37 PM
