Gas Mileage - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 16 (permalink) Old 12-22-2008, 09:09 PM Thread Starter
lynger's Avatar
Gas Mileage
Well, when I first got my truck the gas mileage sucked, so I put a bottle of injector cleaner in. I gained about 120kms with that. Then the truck starting acting up.....long story short I replaced the fuelpump,throttle position sensor and finally the computer. It solved that problem, but the fuel milage went down to 200kms a tank on a good week. Just wondering if you guys had any thoughts on why the mileage got worse....could it be that it is running better than before, therefore using more gas....???? Its the only reason I can come up with.
Josh
lynger is offline
post #2 of 16 (permalink) Old 12-22-2008, 09:20 PM
you're not driving more "spiritedly" now that the truck is running better are you winter fuel could be hurting your mileage,change the air/fuel filters? haven't got a dragging brake? i'm outta ideas.
post #3 of 16 (permalink) Old 12-22-2008, 09:54 PM Thread Starter
lynger's Avatar
Originally Posted by Northern Supercrew View Post
you're not driving more "spiritedly" now that the truck is running better are you winter fuel could be hurting your mileage.
lol no, I changed the fuel filter and air filter. The truck has been like this since the summer when the work was done, I'm leaving for school soon and the less gas I have to put in it the better. Thanks for the ideas.
lynger is offline
post #4 of 16 (permalink) Old 12-23-2008, 12:23 PM
Josh
Josh:the pcm you put in it was it a used or new part?was it for the right eng size(5.0or 5.8l)auto or man trans,have you looked at the plugs and wires(you can tell alot about how an eng is running from the plugs.
post #5 of 16 (permalink) Old 12-23-2008, 03:33 PM Thread Starter
lynger's Avatar
Well the garage put it in but it was new, and I'm assuming that it was for 5.0L and standard tranny. The plugs, wires and distributor cap have all been replaced in the last 4-5 months. I'll check everything over and see what colour the plugs are.
Josh
lynger is offline
post #6 of 16 (permalink) Old 12-29-2008, 09:28 PM Thread Starter
lynger's Avatar
Checked the plugs today, they're a brownish tanish colour, normal I think. I'm honestly not shure what else could cause this.
Thanks for any help guys.
Josh
lynger is offline
post #7 of 16 (permalink) Old 03-09-2010, 11:06 PM
How's the ATF level in the tranny? And for the better question which tranny have you got M5R2 or Zf S5-42? If it's the M5R2, how's it shifting? Could it be the input/mainshaft pocket bearing seizing up?
post #8 of 16 (permalink) Old 04-14-2010, 08:48 PM Thread Starter
lynger's Avatar
Well here's the scoop guys.
Honestly not 100% which tranny but it shifts fine, doesn't seem to be acting up.
So I noticed yet another decrease in gas milage so I got off my ass and did some searching. I got the codes from the computer.
31 - PFE,EVP or EVR circuit below minimum voltage.
32 - EVP voltage below closed limit
41 - No HEGO switching detected
41 - HEGO sensor circuit indicates system lean.
42 - HEGO sensor circuit indicates system rich.
So some other symptoms are the engine lopes at idle..exhaust smells very rich..even some black smoke.
My EGR vale has been disconected since I put an exhuast on it...and the issues didn't start until at least 6 months after that...guess it could still be it though. I'm thinking the oxygen sensor is toast..or just acting up because the engine isn't running properly.
Thats all I can think of at the moment..again thanks for the continued help.
Josh
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
lynger is offline
post #9 of 16 (permalink) Old 04-15-2010, 06:15 AM
Why is the EGR valve disconnected? A stock computer will need that working in order to measure out fuel according to its programming.
post #10 of 16 (permalink) Old 04-15-2010, 08:07 PM Thread Starter
lynger's Avatar
The vacum lines and electrical is hooked up...the tube just isn't connected to the exhaust pipe. When the exhaust was done they just welded a bolt in to plug it...I always wondered but until recently havent had to much trouble with it. I'll have to talk to these guys and find out why they didn't hook it up.
lynger is offline
How much does gas mileage improve after initial break in? Naa_Danno Ranger Forum 28 04-18-2011 08:31 AM
Actual Mileage with 6.4 HTRDDSL Super Duty Forum 24 11-12-2008 12:15 PM
Fuel Mileage redbull2008 Ranger Forum 34 08-17-2008 05:53 PM
Fuel mileage truckpilot F-150 2004 to 2008 Forum 8 08-13-2008 03:12 PM
Mileage on your truck fordtough.ca Gas Engines 4 06-17-2007 11:01 PM
