transmission question - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 02-06-2009, 08:28 PM Thread Starter
I have a 94 f150 with a I-6 and my transmission is gone. I have a really good deal on a tranny from a 2000 4.6L. Is the tranny off the 4.6L an E40D? will it mount on my I-6?
thanks
Jensen is offline
post #2 of 4 (permalink) Old 02-06-2009, 11:00 PM
only tranny's you can use are ones from the I6, 5.0, 351. Bolt patterns match. Otherwise you gotta change bellhousings
post #3 of 4 (permalink) Old 02-08-2009, 11:54 AM
the trans in an 00 4.6l was an 4r70w,and is not the same bell housing config as the older I6/5.0/5.8l eng,what is wrong with the old trans?the e4od isn't that bad to rebuild and a reman isn't to badly priced.
post #4 of 4 (permalink) Old 02-08-2009, 04:24 PM
What Transmission do you have? fordtough.ca Driveline and Transmission 34 04-04-2010 10:00 AM
ENGINE AND TRANSMISSION CODES 1991 TO 1996 fordtough.ca Sticky Tech/How to Section 1 03-17-2009 07:17 PM
ford transmission spotter's guide Northern Supercrew Sticky Tech/How to Section 3 09-26-2008 01:21 AM
What Transmission Temperature......... fordtough.ca Driveline and Transmission 1 06-28-2008 11:02 PM
What Transmission? Disposable-Hero F-150 Pre-1997 Forum 5 01-22-2008 11:26 PM
