Airbag light flashing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 02-12-2009, 05:30 PM Thread Starter
The air bag dash light was flashing this afternoon....the operators manual just says to get the air bag serviced...anyone know what this all means, apart from the obvious? I wonder if it just caused by our rapid drop in temp's today as we went from above zero (C.) to about -10 in 6 hours or so...
truckguy94 is offline
post #2 of 15 (permalink) Old 02-12-2009, 06:10 PM
where is shelbyx1 when we need him? Cause I have no idea
post #3 of 15 (permalink) Old 02-12-2009, 08:11 PM Thread Starter
checked the U.S. F150 site...they have that link to the answer site...Ford mechanic said I need to get it checked as something has failed and the airbag is effectively disabled til the code is corrected...a disabled airbag is not a huge concern for me, so I will get it checked, I just will not drop everything to do that...lol
post #4 of 15 (permalink) Old 02-12-2009, 10:04 PM
zip
zip's Avatar
When it flashes it should flash a code. For example 2/7. Which is one I had with my 99 superduty. If it does flash a code someone should know what it means.
Chris
75 F150, 79 Bronco
zip is offline
post #5 of 15 (permalink) Old 02-13-2009, 11:45 PM
just count the flashes when you put key in run and i'll get you the code discription and possible fixes.
post #6 of 15 (permalink) Old 02-16-2009, 09:18 AM
They do flash a code....There are quite a few.....
If it is the most common one....which is 3-2
It is a clockspring which now needs to be changed....before it throws the thermal fuse which will give you another code altogether....and then you will have to fix both. It is not a really hard job to swap, just a few tools & a six pack.
1994 F-150 supercab 2x4 300-L6
1994 Bronco XLT 4x4 302-V8
Ottawaguy is offline
post #7 of 15 (permalink) Old 02-17-2009, 09:29 AM Thread Starter
Since the codes flashed the one night, it has not repeated, so I am waiting on the codes to report them...thanks
Bill
post #8 of 15 (permalink) Old 02-28-2009, 06:37 PM Thread Starter
OK, the airbag light FINALLY flashed again, today...it was flashing 3/2...pretty sure I got that correct as it is easy to count the flashes...did it a couple of times slowly....
Bill
post #9 of 15 (permalink) Old 02-28-2009, 10:33 PM
Bill:code 32 is for a rh air bag circiut open/or high resistance,do you have any other concerns like horn not working or cruise switches not working?if so you could have a bad clockspring.
post #10 of 15 (permalink) Old 02-28-2009, 11:20 PM
Pfffffft... wussy airbags! You just need a BIG ASS winch bumper to obliterate anything in your path - problem solved! Then THEY need to be worried about THEIR airbags! LR
HID Light Problem.... Need Help??? ChadH F-150 2004 to 2008 Forum 5 12-31-2008 03:08 AM
Better light for pics v8ranger Ranger Forum 1 12-31-2008 01:20 AM
Airbag,code 27 blueghost F-150 2004 to 2008 Forum 1 05-16-2008 10:16 PM
Rear light bar fordtough.ca Lighting 17 12-21-2007 11:47 PM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 09:21 PM
