NEED HELP: 1990 F250 4x4 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 04-07-2009, 07:32 PM Thread Starter
Exclamation 1990 F250 4x4
I recently bought a 1990 F250 4x4 5 spd regular cab. and this is what I would like to do with it. I have been after such a truck for a couple years. I had to settle for a fixer upper. Everything is pretty much going to remain the same.
1. Cab changeover. I would like to go with a newer cab and front clip out of a 91 and up-
Anything I should consider before doing this? I was told the cab/clip would fit, and the mounts are the same.
Henry Ford is offline
post #2 of 3 (permalink) Old 04-07-2009, 08:17 PM
post #3 of 3 (permalink) Old 03-09-2010, 10:29 PM
If you could get a doner truck, I'd go with a 94-95. 1996 had OBDII systems, so I'd stay away from these unless that's what your after
1990 ranger Suggestions? corpral diaz Ranger Forum 6 10-25-2008 11:35 PM
F250 Burnout Bush_aholic Super Duty Forum 0 09-27-2008 12:37 AM
1990 F350 Fuel Problem carriyoung Gas Engines 3 12-01-2007 12:45 PM
