Grounds - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 22 (permalink) Old 04-15-2009, 01:19 AM Thread Starter
kidd's Avatar
Grounds
How many Grounds should there be from the motor to the frame and or to the body, 1994 F150 XLT-5.0-automatic ??
13.32 @ 99.79mph
60' @ 1.86
www.kdracingteam.com
kidd is offline
post #2 of 22 (permalink) Old 04-15-2009, 03:52 AM
I just have 1 grounding strap directly from my block to my frame on my 96 Kirk
post #3 of 22 (permalink) Old 04-15-2009, 04:12 AM
On most Fords there's the one main ground from the battery to the frame to the block/starter. This is more than enough, but there's several other smaller grounds as well for different accessories. Are you having ground issues at all? LR
post #4 of 22 (permalink) Old 04-15-2009, 11:33 PM Thread Starter
kidd's Avatar
Shutting Down then Restarts
Having a problem with my MSD when hooked in the truck runs for a while (20-30 min.) then wants to stall or does. Have been driving it then it stalls, have to restart, then the other night going from Windsor to Chatham it shut down then re-started while it was rolling but then I had to pull off at hwy.77 and it was like running on 5 cyl. and check eng. light came on and pushing Black smoke out the pipes. Called the wife for a ride home and while waiting I pulled the battery cable and let sit for 20 or so minutes, then replaced the cable and it started right up hitting on all 8 cyl. so I had the wife follow and I drove it to Chatham and it was running good, but on the trip from Windsor to 77 it hick-uped a few times and wanted to change gears but then switched right back again ??
Seems like I am losing power or the ground and it resets itself and it is more pronounced when the MSD is hooked in the system and if I unplug the adapter harness and go just reg. ignition the problem is not as often or as bad ??
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
post #5 of 22 (permalink) Old 04-16-2009, 03:03 AM
Kirk check the ground that goes from the battery to the passenger side fender at the front beside the battery
post #6 of 22 (permalink) Old 04-16-2009, 06:17 AM
swackly's Avatar
On my 91 f150 the computer is down on the drive side sort of near the wheel the wires would get loose and it would do the same thing I would un hitch the battery and get some contact cleaner and spray the plug to the computer It worked for me?
swackly is offline
post #7 of 22 (permalink) Old 04-16-2009, 10:05 AM Thread Starter
kidd's Avatar
Ok thanks Jim , already cleaned that one good and will try what swackly said and I can make sure my SuperChip is still making good contact ion the J3 port.
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
post #8 of 22 (permalink) Old 04-16-2009, 10:08 AM Thread Starter
kidd's Avatar
Double post, sorry.
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
post #9 of 22 (permalink) Old 04-16-2009, 03:00 PM
sounds like your msd mod is overheating.
post #10 of 22 (permalink) Old 04-16-2009, 07:42 PM Thread Starter
kidd's Avatar
New MSD Unit
No its mounted inside the cab and New from MSD as a replacement because of the same problem end of last season, and the box was checked out to be ok. This also happens when my MSD is not even hooked up, so the problem has nothing to do with the MSD.
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
