91 f150 fuel gauge not working???????????? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 04-26-2009, 07:58 PM
blazinjames
Guest
Posts: n/a
I have a 91 f150 4.9l automatic with dual metal gas tanks
and when i have the tank set to the front one the gauge reads empty but the pump works well.
how is the best way to test what is wrong? is it the sending unit? fuel pump? just the float and lever?
i have pulled the tank and pump out and now im stuck and not sure what to do to fix the problem
please help with troubleshooting and advice on what to do??
James
post #2 of 3 (permalink) Old 04-26-2009, 08:05 PM
since the pump is working odds are it's a float problem
post #3 of 3 (permalink) Old 04-28-2009, 03:08 PM
check resistance of the sending unit while moving the float arm,should change smoothly with no opens.
GAS GAUGE enjoy425 F-150 1997 to 2003 /04 Heritage Forum 2 04-12-2009 12:37 PM
Aeroforce Scan Gauge Chuck P Audio and Electronics 12 10-23-2008 08:16 PM
Gauge cluster swap on a 97-98 F150 with analog odometers f150phule Sticky Tech/How to Section 2 10-20-2008 01:09 AM
Installed new gauge cluster w/Tach f150phule Interior 9 10-19-2008 06:51 PM
White Gauge Overlay Chienlaid Ranger Forum 5 03-04-2008 09:49 PM
