NEED HELP: stuck in 4 lo - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 08-16-2009, 04:46 PM Thread Starter
4x4truckguy's Avatar
stuck in 4 lo
Hello. I have a 92 ford f150 4x4 auto tranny with autohubs and push botton 4x4. I can not get my transfercase to come out of 4 lo. If I push the 4x4 botton nothing will happen. I tried backing up and nothing. I check the fuse and it looks fine. Any one who can help me out with this will be great. Thanks
4x4truckguy is offline
post #2 of 6 (permalink) Old 08-16-2009, 05:49 PM
my buddy had the same problem with his 91. Turned out his transfer case was screwed
post #3 of 6 (permalink) Old 08-16-2009, 11:48 PM
are the 4x4/4x4 low lamps flashing?if so it could be a module fault,i have seen a few shift motors go south,try removing shift motor on t/case and manually moving lever into gear(this will tell you if the t/case shift fork is ok)than switch t/case motor to see if that works useing 4x4 switch.
post #4 of 6 (permalink) Old 08-20-2009, 11:02 AM
i would try the shift motor for the tcase.....
post #5 of 6 (permalink) Old 09-16-2009, 02:11 PM Thread Starter
I got it fixed. turns out the T case motor was seized up. So I bought a new one
post #6 of 6 (permalink) Old 09-16-2009, 06:37 PM
Good to hear it was an easy fix
Mazda stuck lynger Photo and Video Gallery - Members Rides 6 04-14-2008 12:38 AM
Post Em.. Stuck and Or Muddy!!! Redneck33s Photo and Video Gallery - Members Rides 6 01-02-2008 09:33 PM
Stuck? Ford rescue :) Bush_aholic Photo and Video Gallery - Members Rides 12 12-31-2007 03:17 PM
