starting point project truck 1990 F250 5.8L 5spd 4x4....body swap with 1994 F150 5.0L AT 2wd
problems:
Computer- ok I know I need another CPU from another 4x4 (92-96/5.8L) no problemo cept dont have time to search
Wiring harness- me thinks it would be easier to replace the entire harness with 4x4 (92-96) instead of trying to make heads or tails of it, splicing etc neurtral start switch
Speed Sensor-have some idea? no idea, just dont know. i looked at it though
Neutral Start Switch- goes on inside firewall over clutch push rod, problem is no connector, hope to solve this by switching over harness inside cab-done dealio?
Questions: I have a 1995 F150 6 cyl 5 spd 4x4 lined up for parts but before I make the investment I need to know if the sensors/harness I need here will enable me to complete my project. seeing as it is a 6cyl F150 4x4 going onto the 1990 gearbox.
NOTES: From the 94 F150 automatic there are three plugs going to the transmission meanwhile on the 90 F250 std gearbox there are no receptacles for the plugs.
I imagine one would be the neutral start sensor, one would be the speed sensor, and the third would be the for AOD transmission?
IF anyone has these parts available let me know. I would like to get this project on the road.
oh yeah lots of updates coming up.
i rebuilt my F350 Crewcab or as I like to call her, The Only Thing That Pulls Its Own Weight Around Here! Got a 95 F250 4x4 At for the winter roads. Want the project truck going though, cause five speed standard is the true hauler.
problems:
