86 Ford F150 302 rclb 2wd - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 01-26-2010, 07:16 PM Thread Starter
Just picked up a new project truck, I've been jumping from brand to brand lately and the all seem to of had problems.... So I went back to a ford. It's the 86 f150 reg cab long box 302efi auto XL. All the fluid needs to be changed on it the air filter has the most oil and crap build up I've ever seen on a filter, but she fires up in under a second and runs like a champ. Now, she seems to bog down everytime I need to start from a stop light so I have to start slow and work my way up to speed. I put the truck down into first and it went away when I started. So its my transmission.... but would a simple trans filter and fluid eliminate this? Also does anyone have any specs on these trucks transmission wise and rearend wise? Can't seem to find a tag with all this info on it. Thanks and glad to be back on the forums.
Jensen
Jensen is offline
post #2 of 13 (permalink) Old 01-26-2010, 10:49 PM
If the tranny is a 3-Speed it'll be a C-6. If it's 4-Speed it'll be an AOD.
The rearend could be a Ford 9" (easy to tell if there is no rear cover) or it will be a 8.8" which I think Sterling made (It'll have cover and is a c-clip rear like chev's). 3.50 to 1 is a common gear ratio in the 9". 8.8" could have 3.54 to 1.
post #3 of 13 (permalink) Old 01-26-2010, 11:43 PM
actually the 8.8 would be 3.55 to 1 not 3.54
post #4 of 13 (permalink) Old 01-27-2010, 09:37 PM Thread Starter
At the time of posting the first post it was too dark to see under the truck and my wife hoarded all my flash lights. It is a 3 speed so a C6 and the rear end has a bolt cover so it's the 8.8. I heard somewhere either the C4 or C6 was a bullet proof trans, My plan was to throw a slap shift in it but what performance parts are recommended for the trans with a mildly built 302?
Jensen is offline
post #5 of 13 (permalink) Old 01-27-2010, 11:27 PM
I used a B & M ZGate floor shifter when I had the C6 in mine. B & M also makes some really good shift kits for the C6
post #6 of 13 (permalink) Old 01-28-2010, 03:52 PM
Transgo also makes great shift kits http://www.transgo.com/sk_ford.php
post #7 of 13 (permalink) Old 02-07-2010, 06:46 PM
kidd's Avatar
I use this one in the Level 2 set up works great, shooting 125HP shot (lots of 1320s on it)no slippage or damage yet, been in use for 4 years with out a problem.
AODE and 4R70W Kit: AODE PSK Automatic Shifts
4 Speed Rear Drive Kit: AODE-S PSK Stick Shift
1991 to 2003: 3.8, 4.6, 5.0 5.8 Ford Lincoln Mercury cars and Trucks
Features: Adjusts Smooth to Killer Full Race: Manually holds 1st, 2nd, 3rd any RPM. Manually downshift any gear at any speed.
Stick Shift: All shifts are made by moving selector. No shifts are automatic
13.32 @ 99.79mph
60' @ 1.86
www.kdracingteam.com
kidd is offline
post #8 of 13 (permalink) Old 02-07-2010, 11:57 PM
cept first of all his is an 86 and second it's a C6 tranny.
post #9 of 13 (permalink) Old 02-08-2010, 07:22 PM
kidd's Avatar
Just letting him know the Quality of the TransGo shift kits.
13.32 @ 99.79mph
60' @ 1.86
kidd is offline
post #10 of 13 (permalink) Old 02-08-2010, 10:36 PM
this is what ur lookin for.
http://london.kijiji.ca/c-cars-vehic...AdIdZ181623886
89 f150 5L AT 2WD Henry Ford F-150 Pre-1997 Forum 2 04-26-2009 09:20 PM
NEED HELP: 89 f150 5L 2wd AT Henry Ford F-150 Pre-1997 Forum 5 04-21-2009 03:09 PM
302W or 302 TDC1974 F-150 Pre-1997 Forum 3 05-19-2008 03:26 PM
