Rearend Help - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 16 (permalink) Old 03-10-2010, 08:43 PM Thread Starter
Rearend Help
I know my old truck project isn't a posi rearend and I have heard of guys welding there's. So got board and took the truck to my dad's shop which has welders torches and everything. So I opened the rear diff drained the oil clean it out niiice, and then proceeded to weld, after sitting 4 hours to cool I then put the cover back on with a new gasket and filled with new oil. To make sure I did a good weld I decided to do a burn out in the shop and well my u-joints broke and the drive shaft flew across the shop. Here's a pic of my weld I really need help with this Thanks.
post #2 of 16 (permalink) Old 03-10-2010, 08:53 PM
Well the weld looks good.
lol
post #3 of 16 (permalink) Old 03-10-2010, 08:54 PM Thread Starter
I did some test welds on a scrap piece first with a mig welder
post #4 of 16 (permalink) Old 03-10-2010, 11:06 PM
hope you aren't expecting those gears to last very long! Or you're planning on doing nothing but driving in straight lines!
post #5 of 16 (permalink) Old 03-10-2010, 11:15 PM
no wonder the u joints went...you can't weld the ring to the pinion...lol..you weld up the side/spider gears to make a locker....i would like to have seen the carnage..haha
post #6 of 16 (permalink) Old 03-10-2010, 11:15 PM
i have seen this posted on other forums before. but the first time i saw it it was funny
Adam06FX4 is offline
post #7 of 16 (permalink) Old 03-11-2010, 01:16 AM
I didn't look at the pic before! If the ring and pinion are welded together the rear end can't rotate at all!
post #8 of 16 (permalink) Old 03-11-2010, 07:06 AM
Oops!
post #9 of 16 (permalink) Old 03-11-2010, 08:05 AM
few to many beers perhaps.... lol
post #10 of 16 (permalink) Old 03-11-2010, 03:06 PM
the problem is you only welded 2 teeth togetherlol
rearend??? 94f150 Driveline and Transmission 5 10-23-2008 08:25 AM
