big block? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 04-29-2010, 09:41 PM Thread Starter
big block?
hey guys im wondering if any one on here has tried to put a 428 big block in a 94 f150? any tricks or suggestions? also putting in all 1 ton running gear and a 4 speed tranny... just wondering if any of that has kits or all custom fab work? any help would be great thanks guys.
94f150 is offline
post #2 of 7 (permalink) Old 04-30-2010, 12:43 AM
I'm building a 429 to put in my 96. There are kits out there to do it. If I remember right they're about $1300
post #3 of 7 (permalink) Old 04-30-2010, 11:52 AM
429/460 is a common swap in older fords. The 428 is not very common though, they have a different bell housing pattern (same as 360/390) and you may have trouble finding parts like motor mounts and headers that are readily available for the 429/460 swap.
post #4 of 7 (permalink) Old 04-30-2010, 01:28 PM
the swap kits include motor mounts and headers. I'll see if I can find the site
post #5 of 7 (permalink) Old 04-30-2010, 01:37 PM
L&L makes the kit for the 429/460. Here is one link of many I'm sure: http://www.landlproducts.com/default.aspx
post #6 of 7 (permalink) Old 05-23-2010, 03:28 AM Thread Starter
awsome thanks guys i just picked up wat i thought was a 460 and im running the numbers on the block and it could turn out to be a 429 i picked it up for 100 bucks running pulled it apart and really clean!! thanks for the help and ill keep ya guys posted on the build
94f150 is offline
post #7 of 7 (permalink) Old 05-26-2010, 11:16 PM
Hi new here but not to the trucks and big blocks.
swap kit is not a necessity. 460's came in these trucks 83-97. definitly used OEM parts.
YOu do have to hunt a bit to find what you're looking for, so if time is an issue, the kit is the way to go.
hardest part to find. Oil pump pickup tube.
B Rent is offline
1986 stepside rear brake dist block scottm F-150 Pre-1997 Forum 4 03-15-2010 12:34 AM
Inline block heater Justin1635 Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 5 01-05-2010 12:46 AM
BLOCK HEATER MississaugaRanger Ranger Forum 30 03-06-2009 11:28 PM
The Big One lowlow Ontario 6 02-10-2009 05:10 PM
