1967 f100 serial number - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 05-02-2010, 06:39 PM Thread Starter
I just recived a f100 that i have been trying to get for years and i finally got it.So i was wondering if anyone can tell me what the codes mean for this truck befor I start working on it.
SERIAL # F10VCB02660
DOOR TAG
WB COLOR MODEL BODY TRANS AXLE MAX GVW lbs CERT.NET.HP RPMDS
131 MJ F100 181 G 17 05000 172 4000 B47441
Any and all help would be appreciated thanks in advance.
big-papa is offline
post #2 of 6 (permalink) Old 05-02-2010, 07:34 PM
Denis254 or zip will probably be able to help you with that
post #3 of 6 (permalink) Old 05-03-2010, 02:35 PM
This info is taken from my 1967 Ford/Mercury shop manual.
SERIAL # F10VCB02660 breaks down like this:
F10 is the series = F100
V is the engine code = there is no "V" for 1967 double check if it is a "Y" which is a 352
C is the assembly plant code = Ontario
B02660 is the consecutive serial number = built in April of 1967
131 is the wheelbase in inches = 131 inches (basically a standard cab with 8 foot box)
MJ is the exterior paint color = White (M) & Red (J)
F100 is the model = F100
1 is the interior trim code = Gray vinyl (I am a little surprised here)
81 is the cab or body type = Conventional cab
G is the transmission = Automatic C4
17 is the rear axle code = Ford 9 inch, 3.25 ratio, 3300 lb rating
05000 is the gross vehicle weight (GVW) = 5000 lb
172 is the certified net horsepower = 172
4000 is the RPM at the certified net horsepower = 4000 RPM
B4 is the Ford of Canada district code = Midwestern Region
7441...........I can't find anything on this. Maybe some sort of "Canadian" serial number???
I have been working on 67-79 Fords for quite a few years and I have 3 1967's in various states of disrepair. Your truck is not real common......if it still has the 352 engine. The 352's were only used in trucks from 1965-67, making 1967 the only "bumpside" to have a 352.
I am in the Winnipeg area and am always willing to share information--let me know if you want my contact info. Greg.
Red Mercury is offline
post #4 of 6 (permalink) Old 05-03-2010, 07:58 PM
thanks for posting that Greg and welcome to the site
post #5 of 6 (permalink) Old 05-03-2010, 10:29 PM
zip
zip's Avatar
Well that's a whole lot better than I could have done.
Welcome to the site Greg.
Chris
75 F150, 79 Bronco
zip is offline
post #6 of 6 (permalink) Old 05-03-2010, 11:43 PM
Beginner's luck, big-papa happenned to ask the right question!
It's good to stumble across a site with some Canadian flavour.
Greg.
Check out this sick 1951 F100 burtoj2 Truck/SUV Talk 8 08-19-2009 12:32 PM
Grille number 3. gewiens Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 4 03-20-2009 11:15 PM
FORD VIN NUMBER DECODER fordtough.ca Sticky Tech/How to Section 4 08-19-2008 12:00 AM
New F100 out in '09??? f150phule Ranger Forum 34 03-20-2008 06:48 PM
