NEED HELP: oil pressure - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 05-13-2010, 05:33 PM Thread Starter
oil pressure
Hi guys i have trouble with my oil pressure its fine when the truck is cold but after 20 minute running so i guess when the oil gets really hot, i stop at the lights and the pressure drops to 0 and the engine light comes on i did an oil change and put some thicker oil in but it still does it so you guys have an idea what can i do? Thanks
89f150 is offline
post #2 of 3 (permalink) Old 05-13-2010, 07:15 PM
are you using an aftermarket pressure gauge or just the factory dash one?
post #3 of 3 (permalink) Old 05-14-2010, 03:51 PM
do you have a oil leak from the sender area?also use a manuel oil press gauge to test as the factory gauge isn't all that accurate.
Tire Pressure - BFG A/T T/As Blue Oval Wheels and Tires 6 11-22-2009 02:45 PM
99 Ranger - Cold Start, Low Oil Pressure 00PowderSpecial Ranger Forum 5 12-19-2008 01:10 PM
Changed oil pressure sending unit today Larry227 F-150 1997 to 2003 /04 Heritage Forum 1 09-14-2008 06:10 AM
