NEED HELP: wiring problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 06-17-2010, 01:22 AM Thread Starter
wiring problem
sorry for makin you guys read this but, im puttin in a one wire alternator in the truck, i put the green and yellow wire togther, with the voltage wire for the dummy light on the positive post of the starter solenoid, and got rid of the voltage regulator, and put everything back togther..
#2 i installed a msd box with a billit distributor, i left the dura junk hucked up and the instructions said to use the red 12v switched ing wire witch is the coil + wire for the dura junk. so i did all that, now im getting a pos feed back threw the coil with the key off and im not gettin the s terminal on the starter solenoid to work... and yes the solenoid does work. i tested it.
i know this is a lil crazy and maby hard to understand but im a few beers in and its a lil late..... just wanna get the dam thing started..lol
thank you.
post #2 of 2 (permalink) Old 06-17-2010, 01:44 PM
Can you post a simple diagram of what you've got now?
Trailer wiring littlebronc F-150 2004 to 2008 Forum 6 07-03-2009 09:51 PM
LF Wiring Diagram Swoosh66 F-150 2004 to 2008 Forum 5 11-18-2008 09:08 AM
Anybody on wiring ? Umaxman Audio and Electronics 2 05-25-2008 08:44 PM
94 ranger trailer wiring problem krazykanuk Ranger Forum 5 04-17-2008 11:33 PM
